wheel fitment questions.
Old Nov 12, 2008 | 01:50 PM
N_Vigz's Avatar
Default wheel fitment questions.
looking to pick up some new 15's.
i would like to get some wider wheels but am not too familiar with the offsets for my new 91 hatch.
if i were going to run 15x9 in the rear and 15x8 in the front, what offsets should i look for?
thanks.
-Nick.
Old Nov 12, 2008 | 05:41 PM
TunerN00b's Avatar
Default Re: wheel fitment questions. (N_Vigz)
thanks.
-Nick.
Um, you'll never find tires in the appropriate size for wheels that wide. For offset, I'll let other answer as I have no experience with that chassis.
Additionally, why run a wider rear wheel? The front tires do all the work, and the front fenders have a larger opening to accommodate a wider wheel anyway.
Originally Posted by A-to-the-J
Don't mean to thread jack, but I have a question too.
would a 15x8 +15 all around fit on an 88 LX Sedan? What tire size would be good?
The wheels would fit (sort of, with added camber and rolled/pulled fenders), but same issue as above. You won't find tires in the appropriate size to mount on those wheels.
The correct 15" tire for your car (and the OP's car) is 195/50-15, which are generally approved for 5.5" to 7" wheels.
Are you guys going for the lowrider mini truck look (wheels sticking outside of the body and dangerously stretched tires)?
Old Nov 12, 2008 | 07:03 PM
N_Vigz's Avatar
Default Re: wheel fitment questions. (TunerN00b)
wider rear wheels look better imo.
15x8 all around wouldn't be bad i guess.
and i'll be stretching the tires, most likely a 195/45 on the 8's if thats the biggest i can run.
Old Nov 12, 2008 | 08:26 PM
jdmcivicturbo's Avatar
you can run 195 50's just got to hammer out the fenders or roll with sort of thick stick.... if you know what i mean.. almost as fat as a jack handle.. sort of..
Old Nov 13, 2008 | 02:57 AM
N_Vigz's Avatar
Default Re: wheel fitment questions. (jdmcivicturbo)
yeah thats not an issue.
what offsets should i get though?
Old Nov 13, 2008 | 08:52 AM
nsxtasy's Avatar
H-T Order of Merit
Stretching a tire onto a wheel that is wider than approved for it is UNSAFE. When you do this, excessive stress and heat builds up in the sidewall of the tire, and can lead to tire failure (blowout, etc). DON'T DO IT.
TunerN00b's advice is correct:
Old Oct 17, 2011 | 12:49 PM
EF Boy1231's Avatar
Originally Posted by 89 civic ef
will 15x9 0 offset rims fit my 89 civic ef with out camber?
No
Vinde
Oct 14, 2014 04:02 PM
b0yg0tskills
Feb 16, 2010 06:34 AM
darkwater_ghost
Jul 17, 2009 09:33 AM
primaryOBSESSION
Honda S2000
12
Mar 11, 2009 09:30 AM
Sean @ ESG
Nov 26, 2008 07:32 PM
