ESP EF8/9 B16A1 SiR 5 spd B Series Cable Trans Replacement Motor Mount Kit
Old Nov 12, 2008 | 11:28 AM
ESP.net's Avatar
Default ESP EF8/9 B16A1 SiR 5 spd B Series Cable Trans Replacement Motor Mount Kit
As some of you EF8/EF9 chassis SiR guru's have requested a SIR 5 spd B Series Cable Trans Motor Mount Kit Replacement over OEM here it is.
* Factory EF8/9 SiR B16A1 88-91 Civic SiR and Crx Sir 5 spd
- 70A polyurethane as all our mount kits
- Replaces all 3 mounts, driver, rear and transmission top part. Bottom OEM transmission part needs to be used with this kit.
- Should fit all SiR chassis with Cable B trans, B18A/B/C engines, may need to swap out driver side engine bracket for SiR, as well as use the SiR rear bracket.
- Red or Black insert colors.
We also have the EF USDM B series 5 spd Cable B Motor Mount Kit as well...
Modified by ESP.net at 12:34 PM 11/12/2008
antreasef8
Apr 14, 2012 12:34 PM
da9leo
Mar 14, 2011 08:23 PM
ESP.net
Jan 24, 2008 11:00 PM
enabi
Oct 7, 2002 05:25 PM
Gizmo21
Jun 4, 2002 03:56 PM
