Blower Motor Help
Old Nov 12, 2008 | 10:42 AM
Dbach's Avatar
Default Blower Motor Help
I have a 94 Civic and the heat recently stopped working. I want to do my own diagnostics on the blower motor to decide whether it is my climate control or not. Anyways to my question I am wondering if anybody knows where I should be putting my volt meter when I check my blower motor for power. Where are the positive and negative terminals at? Thanks
Old Nov 12, 2008 | 11:34 AM
addiction2bass's Avatar
Default Re: Blower Motor Help (Dbach)
i believe the motor is reversable... at least when i replaced my 94s blower i could switch the wires to suck or blow depending on polarity. very easy to test out the blower!
if it works when hard wired then check al your fuses and if those are all good then replace the blower resistor unit.
Old Nov 12, 2008 | 12:01 PM
wrenchez81's Avatar
Default Re: Blower Motor Help (addiction2bass)
[QUOTE=addiction2bass]i believe the motor is reversable...
you my friend are correct!!! essentially just put one lead on one side than the other on the other and make sure you get voltage.......
90ED6LSV
Dec 31, 2012 06:42 AM
zeusdavis
Nov 11, 2010 07:43 AM
94trouble
Nov 11, 2010 05:50 AM
Mikej425
Nov 12, 2008 10:40 AM
geezel81
Mar 22, 2008 06:27 AM
