So my car wont start :[
Old Nov 12, 2008 | 01:01 AM
exz0n-.-'s Avatar
Default So my car wont start :[
alright, a little history of my problem:
yesterday my girlfriend had my car and was gonna go do some stuff, so she tries to start it up and it cranks but wont fire.. whatever so i come over and check some **** out. fuel pump wasnt turning on so i wired the fuel pump straight to my ignition, my fuel pump turns on etc and it ran.
so i drive my car to work, after work it starts up fine. i go pick my gf up, go to my house we hangout etc, i go outside to turn my car on to take her home and it wont start again?
im stumped.
88 civic dx, dual point.
im thinking maybe the engine is flooded? im not sure, i can think of what to do.
could my injectors be clogged maybe?
im definately getting fuel, and spark..
so what do you guys think? flooded maybe?
Old Nov 12, 2008 | 07:50 AM
stevew84's Avatar
Banned
your first problem, the fuel pump, is either do to the fuel pump relay or a frayed wire. this happened with my ignition a while back i did what u did...connect a wire from the black/white ignition wire STRAIGHT to the starter, perfect....
get some injector cleaner, COULD help...um check the wire you ran directly to starter who knows it could have come loose.
try to replace the fuel pump relay tho
Old Nov 12, 2008 | 08:50 AM
thorclark's Avatar
Getta new Girlfriend
Old Nov 12, 2008 | 09:13 AM
kiba's Avatar
Default Re: (thorclark)
i agree, i dont think the car likes your girlfriend...
Old Nov 12, 2008 | 11:45 AM
exz0n-.-'s Avatar
ugh. its not my fuel pump cause i took the wire out that went from my ignition straight to the pump and it still turned on.
im pretty sure my car is flooded but i dont have any money for new plugs/plug wires either..[freak] life
Old Nov 12, 2008 | 11:48 AM
stevew84's Avatar
Banned
why do u think that its flooded?
Old Nov 12, 2008 | 11:54 AM
exz0n-.-'s Avatar
because thats what was wrong yesterday when me and my friend fixed it.
it was just dumping fuel into the motor and there was too much so it couldnt ignite it.
now, my house is so [freak]ing stupid i dont even have a ratchet so i can take my spark plugs out and dry them off..this is rediculous
Old Nov 12, 2008 | 12:19 PM
killsnake562's Avatar
Default Re: (exz0n-.-)
That happen to me, my car hated my girlfriend too. Invest into some tools, your ride is like 20 years old. This would be a great time to reconcile with your true love.
Old Nov 12, 2008 | 05:17 PM
exz0n-.-'s Avatar
alright so i got new plugs, it still wouldnt start. so i pulled the cover off on the dpfi throttle body, and squirted some gas in there with a spray bottle while i ahd my gf try to start it.. it started and i drove it around for like an hour...
but my problem is that it wont start up normal with the turn of my key..
i dont wanna keep having to start it by spraying gas into that lol..someone help please!
Old Nov 12, 2008 | 05:31 PM
spoolin94ls's Avatar
u may have a clogged injector, its not droppin enough fuel to start the car
Old Nov 14, 2008 | 08:35 AM
exz0n-.-'s Avatar
ok well i got some fuel injector cleaner, the other day i was able to turn it off, then turn it back on using the key a few times.. i was like wtf it works..
but then it stopped working again lol..
so i keep having to pour a little gas into the dpfi throttle body to start this bitch.. any ideas?
im prolly getting a mpfi swap this weekend but i still wanna figure out whats wrong
Old Nov 14, 2008 | 08:39 AM
stevew84's Avatar
Banned
if the injector cleaner worked....then jacked up again...it means you need to replace your injectors.
if you have the money, just overhaul your fuel system i mean **** it will fix your problem.
go all out get a pump, rail, and injectors. you may even want to get a cheap fuel pressure regulator, or at least a gauge that lets u know whats up. or get an adjustable regulator.
Old Nov 14, 2008 | 08:43 AM
exz0n-.-'s Avatar
hm. well if i was planning on keeping the dual point i would do all of that but im just gonna say [freak] it and buy the multi port swap so i can have 4 fuel injectors and no gay throttle body/fake carb thing hahaha..
this is stumping me though, cause when i get it started it runs normally, but then i turn it off it just wont turn back on unless it has gas in the throttle body
Perkul8r
Aug 4, 2009 10:57 AM
teg racer 877
Mar 5, 2009 05:40 PM
devin_hoang
11
Dec 31, 2008 06:01 PM
sung
Feb 16, 2005 07:19 PM
lawlerlaw
Nov 16, 2004 01:25 AM
