OEM JDM 4-1 Header + JDM cat = direct bolt on to USDM exhaust?
Old Nov 12, 2008 | 12:51 AM
redGSRguy's Avatar
Default OEM JDM 4-1 Header + JDM cat = direct bolt on to USDM exhaust?
I have a JDM 4-1 and from what I've seen around is that the length will be right but is the cat outlet 2.5"? Will it bolt to the stock piping?
I understand that the jdm header has no O2 sensor but I will be running hondata so hopefully that will not be a problem.
Old Nov 12, 2008 | 06:07 AM
be18see1's Avatar
Default Re: OEM JDM 4-1 Header + JDM cat = direct bolt on to USDM exhaust? (redGSRguy)
i dont think so.
Old Nov 12, 2008 | 06:33 AM
sitinduk's Avatar
AFAIK 98+ jdm itr header does have an o2 bung. The jdm cat does not.
Not sure if the jdm cat exit will bolt to a usdm itr b-pipe, but I know it won't bolt to a smaller diameter ls or gsr b-pipe.
Which b-pipe do you have?
Old Nov 12, 2008 | 08:22 AM
joni_titi's Avatar
Are you sure it will be the good lenght because te jdm cat is shorter tna the USDM
Old Nov 12, 2008 | 09:20 AM
redGSRguy's Avatar
Default Re: (joni_titi)
I have ITR b-pipe.
The jdm header is longer than the usdm one. Can anyone confirm if this will fit?
Old Nov 12, 2008 | 12:55 PM
sitinduk's Avatar
Default Re: (redGSRguy)
Originally Posted by redGSRguy
I have ITR b-pipe.
It might fit diameter wise, but length is most likely different. Welding is probably required.
I got a jdm itr b-pipe from passwordjdm.com to bolt up to my dc sports jdm 4-1 header, jdm itr cat, and usdm itr muffler.
Old Nov 12, 2008 | 01:15 PM
siRone's Avatar
Lookin to keep a low profile on the exhaust note huh?
Old Nov 12, 2008 | 01:16 PM
siRone's Avatar
Default Re: (sitinduk)
Was it direct fitment?
Old Nov 12, 2008 | 10:50 PM
redGSRguy's Avatar
Default Re: (siRone)
Looking to save some money for now.
Does anyone know for sure? Right now it seems that jdm header + jdm cat + jdm bpipe = win?
Old Nov 13, 2008 | 08:22 AM
sitinduk's Avatar
Yeah, got a ticket for a apexi wsii.
DC sports jdm 4-1 header->jdm itr cat->jdm itr b-pipe->usdm itr muffler is a direct fit, bolt up affair. It will only have 1 o2 bung in the header, so another o2 bung will have to be welded on somewhere after the cat for obd ii.
Old Nov 13, 2008 | 10:36 AM
siRone's Avatar
Where did you get your jdm cat? And did you leave it as is or hollow it out?
Old Nov 13, 2008 | 11:47 AM
sitinduk's Avatar
I got mine from another member through the Honda-Tech For Sale forum.
Passwordjdm.com also sells them and the other parts of the jdm itr exhaust (header, b-pipe, muffler).
I left the cat as is to pass emissions.
Old Nov 19, 2008 | 06:39 AM
siRone's Avatar
It was used though right? I plan on buyin one for my setup, i just want it to be a real suttle exhaust note. Im trying to get away from it soundin raspy.
Old Aug 12, 2009 | 06:27 PM
tsgiss's Avatar
New User
Hi guys, Im a newbie. Nice to join this forum.
calcul pret assurance simulation taux emprunt immobilier - Taux emprunt immobilier. Comparez les offres d’emprunt immobilier, simulation emprunt immobilier, taux emprunt immobiliercalcul pret assurance simulation taux emprunt immobilier
jdm_94
May 15, 2009 09:22 PM
ednyboo
Apr 26, 2007 05:10 AM
ebelp
Aug 31, 2004 04:14 AM
austrian type-R
Feb 16, 2004 02:39 PM
2k1TypeR0610
Sep 28, 2001 08:16 AM
