Why is my new clutch slipping?
Old Nov 11, 2008 | 09:16 PM
1990EFHATCH's Avatar
Default Why is my new clutch slipping?
I just baught and installed a new f-1 stage 3 clutch and pressure plate from gripforce on my ef and the adjustment on the clutch is all the way and when i take out the clutch the car starts moving when theres like 2 inches before the clutch pedalis all the way out and the clutch also feels like its slipping?
Old Nov 11, 2008 | 11:20 PM
majinsoftware's Avatar
What iv found with new clutchs is take it easy on them for the first few drives so the can bed in, If it was sitting around with out a cover over it the outside will be dirty And make it slippry till it wears through that bit.
Also make sure you have adjusted it correctly.
Old Nov 12, 2008 | 05:25 AM
HondaKyle's Avatar
Default Re: Why is my new clutch slipping? (1990EFHATCH)
because its an E bay brand?
Old Nov 12, 2008 | 06:57 AM
Sycotic_Intensionz's Avatar
Did you break it in properly?
Old Nov 12, 2008 | 12:41 PM
neardon's Avatar
I'm a Jackass
There should be part of the clutch cable that you can twist to relieve some of the tension. The piece usually sits on top of the tranny right before the cable goes into the tranny.
The old wore out clutch probably caused it to be adjusted how it is now. Its an easy adjustment, just twist, then go in and have a feel for it.
Old Nov 12, 2008 | 01:07 PM
Default Re: Why is my new clutch slipping? (neardon)
My adjustment is all the way up. and i drive it normal shift at 3500rpm each time and i dnt punch on the gas nos double clutch it
Old Nov 12, 2008 | 01:37 PM
danthemang3's Avatar
any reason you put a stage 3 clutch in a pretty much stock car? was the flywheel resurfaced, because that will increase the distance the clutch has to travel. if everything is installed and adjusted correctly then it has to be the clutch.
Old Nov 12, 2008 | 01:43 PM
neardon's Avatar
I'm a Jackass
What happens when you adjust it the other way?
Old Nov 12, 2008 | 01:55 PM
i put a stage 3 because i drive too wild and yes i bought a flywheel from kragen
when i adjust it the other way i it wont engage
Old Nov 12, 2008 | 02:05 PM
thewrai6th's Avatar
Old Nov 12, 2008 | 03:01 PM
j_bizach's Avatar
Default Re: Why is my new clutch slipping? (thewrai6th)
id imagin that you got grease or dirt on the clutch plate, if its an ebay clutch its proly the pressure plate, or you did something wrong while installing it. Either way you mite as well throw it away and get a nice stage one.
-I DONT CARE HOW ANYONE DRIVES A STAGE 2, 3, OR 4 CLUTCH IS NOT NEEDED ON A STOCK OR ALMOST STOCK OR LIGHTLY MODIFIED CAR
Old Nov 12, 2008 | 03:34 PM
kronikSLOW's Avatar
Default Re: Why is my new clutch slipping? (j_bizach)
heres my .02. if youve ever driven a new car off the lot with a brand new clutch. you can push the clutch put it in gear and start to release the clutch slowly and before the clutch is even disengaged and with out giving it any throttle the automobile will begin to go forward at a rate of about 3 mph without any throttle. id say that your just paranoid because you may or may not have ever done a clutch before. give it 200 miles and see if you still think its bad. if you still think its bad go to honda and test drive a brand new one to see how it feels. also have you checked your clutch fluid.
Old Nov 12, 2008 | 05:06 PM
Cable clutch doesnt have fluid.
Yeah give it a week to bed in.
Also when adjusting the clutch cable the leaver on the gearbox should be straight when the clutch pedal isnt pushed. There should be some slack in the cable.(flywheel,clutch,pressure plate against each other)
Then with the clutch pedal pushed it should move up to 9-10 oclock. (throw out bearing pushing against the pressure plate to lose contact with clutch)
Old Nov 12, 2008 | 08:15 PM
stocker2shocker91's Avatar
I requested a short story for a title.
Default Re: Why is my new clutch slipping? (HondaKyle)
i think the only people who complain about them are the ones who install them wrong or beat the living **** out of it right off the bat... i have an f-1 in my car..i broke it in properly and it pulls hard and feels great.
oh ya why is this not in the ef forum??
Old Nov 12, 2008 | 08:34 PM
toofast4u752's Avatar
yeah i had one of those same f1 clutches... worked fine for me... lasted me over a year then i decided to pull it out cuz it was too aggressive... im calling this one install error...
Old Nov 12, 2008 | 08:45 PM
Default Re: (toofast4u752)
so should i like re install the clutch?
Old Nov 12, 2008 | 09:25 PM
InvaderTrax's Avatar
Can you take a picture of your cable adjuster? It shouldn't be "all" the way in one direction or the other...
Old Nov 12, 2008 | 09:31 PM
pokmijn's Avatar
Nothing is wrong with the clutch its just how cable tranny is...just remove the tranny and put it back keep doing that if you want it to feel like it use to. When i first change my clutch in my DA thats exactly what happened to me drove like that for 3 month finally i just detached my tranny and reattached it went back to normal now everytime i change a cable tranny or change the clutch from a cable tranny its takes a while to get it to feel the same.
DO YOU GET WHAT IM SAYING ITS NOT UR CLUTCH SLIPPING
Old Nov 13, 2008 | 09:03 PM
Default Re: Why is my new clutch slipping? (pokmijn)
NOPE I DIDNT UNDERSTAND IT
Old Nov 13, 2008 | 09:08 PM
haha WUT???
Old Nov 13, 2008 | 09:16 PM
Default Re: Why is my new clutch slipping? (stocker2shocker91)
HAHAHA THATS WHAT I SAID
Old Nov 14, 2008 | 04:07 PM
lmike6453's Avatar
Lol, I bought a F-1 racing flywheel w/ Exedy stage 1 clutch and pressure plate from Gripforce...good guys and great product....nothing wrong so far...
I'd say wait some time for it to break in, and if still no dice then replace with stage 1 or 2 for stock.
Old Nov 14, 2008 | 04:15 PM
egsleepercivic's Avatar
I think flywheels come with the same coating as new rotors, so they don't rust in the box, did you clean the flywheel surface with brake cleaner before u installed the clutch? also average break in peeriod is usually like 500 miles for a clutch, just shift easy during the 500 miles
gl
Old Nov 14, 2008 | 10:51 PM
vladd's Avatar
x2. driving habits have nothing to do with what clutch you need. for some reason a lot of people seem to think that having a higher stage of whatever clutch will somehow make their car faster and/or clutch last longer. it does neither.
Old Nov 14, 2008 | 10:52 PM
vladd's Avatar
Default Re: (egsleepercivic)
gl
they do come with a coating. when i installed my exedy flywheel in my gsr i had to clean the contact surface with brake cleaner.
