pink wire on p13 ecu
No help so I will jump with the first silly question as I do not memorize anything. Did that P13 come with your JDM engine. If so, was the entire harness in tact, if it was your original ECU, then what engine was in your car. Can you tell us what pin number that wire is on the ECU please.
I am suprised no one helped yet, these guys really know these ECUs well.
5 minute search came up with this.
ECU PIN # A17 pink IAB Solenoid Valve under intake manifold. Do an archived search for, P13 pink, and do a little reading in the first several posts and posts with both P13 and pink highlighted.
Modified by Duane_in_Japan at 6:52 AM 11/13/2008
Stunna MIKE
13
Feb 6, 2006 10:43 AM
BlueShadow
Jun 1, 2005 10:08 PM
