b16a into crx hf will not start
the battery light doesnt even come on.i left the hood off and it started raining.any suggestions.i tried another battery
Modified by border919 at 12:46 PM 11/14/2008
is the small wire from the positive battery terminal connected at the main under hood fuse box?
Modified by jlicrx at 8:49 PM 11/11/2008
the light that shows the brake is on comes on the dash.and im pretty sure i have the positive wire connected.i had a bad ground.i can now crank it but it sounds like it doesnt want to get gas.im not sure what needs to be done.any suggetions.the starter kicks in and everythings moving but.nothing is firing up
That usually does it.
Also check your thermostat ground,transmission ground.
i fixed most of them and i t was running fine.then i left the hood off on accident in the rain. and i did lower the car down of the standswould that do anything?
Gwyn'sCRX1990
Oct 2, 2014 06:07 AM
