spring rubbing against sleeve = squeaks
Old Nov 11, 2008 | 04:04 PM
baaao's Avatar
Default spring rubbing against sleeve = squeaks
can somebody help me with this problem. my rear, right spring likes the move around and rub around against my sleeves, resulting in squeaking noises. it's getting really bad and i need the spring to sit flush on the perch. any suggestions? thanks. (i have GCs)
Old Nov 11, 2008 | 06:04 PM
majinsoftware's Avatar
well first do you have keeper springs, They are little soft springs that sit on top of the spring to keep load on it so it doesnt move around.
Also can try using electrical tape around the sleeve, What I do but its only really a temporary fix.
Old Nov 11, 2008 | 06:28 PM
baaao's Avatar
Default Re: (majinsoftware)
no.. i don't have keeper springs. they sound like a good idea though. earlier, i jacked up the rear, repositioned my spring, and just sprayed lube everywhere. it's not squeaking anymore and i hope it stops. if not, i think i'm gonna buy a set of keeper springs. do you know where i can get them?
Old Nov 11, 2008 | 08:11 PM
Here in NZ most suspension shops can get them in for you, You are also required to have them to keep your suspension all legal. Dont know the laws over there tho.
KillaB-
Suspension & Brakes
Jan 28, 2005 09:12 PM
Naturally Aspirated
Sep 21, 2004 06:23 PM
akkord94
Dec 29, 2003 02:48 PM
Doctor CorteZ
Feb 27, 2002 06:07 PM
