Ls/vtec help
Old Nov 11, 2008 | 08:31 AM
hbombhondacrew's Avatar
Default Ls/vtec help
i have a b16 intake manifold i just bought it came with everything but injectors and fuel rail. i know that b16 and b18 injectors have the same flow rate, so can i just put the fuel rail and injectors from my b18 onto the b16?
Old Nov 11, 2008 | 10:25 AM
ys1civicsi's Avatar
Default Re: Ls/vtec help (hbombhondacrew)
you should be able to as i believe all b-series fuel rails are interchangeable
Old Nov 11, 2008 | 10:29 PM
oodie's Avatar
Default Re: Ls/vtec help (ys1civicsi)
Yes you can swap them over.
Old Nov 12, 2008 | 06:57 AM
Default Re: Ls/vtec help (oodie)
i know that b18c is interchangable but are you positive an ls will work? im thinking about buying and aftermarket fuel rail even though i dont want to spend the money. can i put the fuel pressure reg. on the b16 rail i think that a b16 is 30lb of fuel and 1.8 is 45lb will this be bad for it with the increased compression?
Old Nov 12, 2008 | 07:45 AM
stevew84's Avatar
Banned
fuel rail depends on the intake manny. im not sure if you can use a gsr rail with an ls intake manny or vise versa.
88 EF Hatch
Sep 4, 2009 06:44 AM
naptownrex
Feb 1, 2005 08:21 AM
b16delsol
Feb 3, 2004 07:40 PM
