need help!! ZC tranny rebuild problem
Old Nov 10, 2008 | 07:30 PM
ponchdriver16's Avatar
Default need help!! ZC tranny rebuild problem
ok guys, i have a problem here. I'm rebuilding my ZC trans because the diff blew into a million tiny pieces. So I get my LSD and all the bearings and seals (used a 91 si as a reference for part numbers) and my new diff bearings are too small. they are actually the same size as the bearings in my LX trans. i don't know what the deal is. Am I referencing the wrong US equivalent? should i be getting 89 integra bearings? anyone with advise who has done this and knows what the hell the right thing is, please help a brother out. thanks
Old Nov 10, 2008 | 08:16 PM
jlicrx's Avatar
Default Re: need help!! ZC tranny rebuild problem (ponchdriver16)
40mm differential carrier bearings are the same as for the 88 CRX Si - Honda part no. 91005-PL3-B04
Old Nov 11, 2008 | 07:29 PM
Default Re: need help!! ZC tranny rebuild problem (jlicrx)
they dont work. the outer diameter of all 88-91 d-series diff bearings (with the exception of the wagon 4wd) is 72 mm. the bearing that came out are 80mm. I just dont know what to cross referance them to. the 91005-pl3-b04 part number has been superceeded by 91005-pl3-008 which is 72mm o.d. thanks for trying
Edit: upon further research i found out that you are right. I'm wrong. the ammended referance number to the B04 bearing is 6208. the same as a 92-95 diff bearing and 88-89 integra diff bearing. the 008 bearing referance number is 6207. I apologize for seeming rude when i hadnt checked out all the facts. thanks for your help.
Modified by ponchdriver16 at 4:35 AM 11/12/2008
zenon8890
Jan 6, 2010 07:44 AM
clsmooth
Feb 25, 2003 05:57 PM
clsmooth
Feb 24, 2003 08:58 PM
travis_118
Mar 24, 2002 12:03 AM
Grumpy
Sep 10, 2001 03:49 PM
