oil swap question
Old Nov 10, 2008 | 04:18 PM
juz10's Avatar
Default oil swap question
i just bought an eg with an ls motor in it, the b18b1
its running about 7 lbs of boost
supposedly the motor has around 35k miles
he told me that he only ran mobil 1 synthetic oil and thats all i should put in it
my question is: is it necessary to run synthetic oil in this motor?
i was going to change the oil because its low and black plus i dont know when it was done last.
my other b18 takes pennzoil conventional pretty much every time and its never been a problem.
im just wondering if swapping from synth to conventional might cause any issues with the engine
your thoughts?
Old Nov 10, 2008 | 04:56 PM
mikehawk's Avatar
Default Re: oil swap question (juz10)
if you want to switch back you need to do a motor flush.. you can buy that stuff from the same place you get your oil usually.. follow the directions
BUT
It is recommended to use only synthetic oil in a turbo application because synthetic oils are better at resisting thermal breakdown then non-synthetic oil, and we all know that turbos run at extremely high temperatures.
Old Nov 10, 2008 | 05:01 PM
juz10's Avatar
Default Re: oil swap question (mikehawk)
i dont know why i didnt just search this instead of making a post
theres plenty of information already about it and search has never failed me before
thanks though
saemoonyang
12
Oct 16, 2011 05:53 PM
EK45VTi
May 28, 2004 08:27 AM
xSCTYGx
May 10, 2004 10:01 AM
DelSolSi93
Nov 8, 2003 10:28 AM
JUNIOR
Sep 14, 2002 03:26 PM
