fuse keep popping problem please help help!
fuse keep popping when i plug up corner lights when i go to turn on the headlights if the corner lights are plugged in, it will pop the fuse for the jdm fog lights also the cluster and interior dome light wont light up i believe they all run off the same fuse ....... if i install a new fuse disconnect the corner lights everything works fine
dont understand what could cause the fuse to pop and suggestions please help.
new bulbs new fuse still no help
do you think it may have something too do with the fog lights. wiring for the corner lights looks fine.
