How do I tell which model CRX I've got?
I bought my CRX a few years back, don't remember which model it is, my title doesn't say. Is there a way I can tell from the VIN? Thanx Kevin
First 3 digits (aaa) MFG, Make, and Type of vehicle
1HG = Honda America, passenger car
2HG = Honda Canada, passenger car
JHM = Honda Motor Co, passenger car
Next 3 digits (bbb) Line/Body and Engine type
ED3 = Civic 1500 Sedan
ED4 = Civic 1600 Sedan
ED6 = Civic 1500 Hatchback
ED7 = Civic 1600 Hatchback
Next 1 digit (c) Trans Type
3 = 4spd and 5spd manual/2door hatchback
4 = 4spd auto/2door hatchback
5 = 5spd manual/4door sedan
6 = 4spd auto/4door sedan
Next 1 digit (d) Model
4 = STD (ED6), DX (ED3)
5 = DX (ED6), LX (ED3)
6 = Si (ED7), EX (ED4)
Next 1 digit (e) Check Digit (Ignore)
Next 1 digit (f) Model Year
M = 1990
Next 1 digit (g) Factory
H = Ontario Canada
L = Ohio USA
S = Suzuka Japan
Last 6 digits (hhhhhh) Serial Number
000001~ = Ohio Made
500001~ = Ontario Made
000001~ = Suzuka Made
Canada Model:
aaabbbcdefghhhhhh
0 = DX (ED6), LX (ED3)
3 = STD (ED6)
4 = CX (ED6), DX (ED3)
6 = Si (ED7)
M = 1991
H = Ontario Canada
S = Suzuka Japan
000001~ = Ontario Made
800001~ = Suzuka Made
Engine Model Numbers:
D15B1 = 1500 Dual Point Fuel Injection 70HP
D15B2 = 1500 Dual Point Fuel Injection 93HP
D16A6 = 1600 Multi Point Fuel Injection 105HP
a little searching never hurt anyone. it says civic but goes for crx also
M = 1990
H = Ontario Canada
L = Ohio USA
S = Suzuka Japan
000001~ = Ohio Made
Canada Model:
aaabbbcdefghhhhhh
3 = STD (ED6)
6 = Si (ED7)
M = 1991
H = Ontario Canada
S = Suzuka Japan
Originally Posted by SlaminRC17
no sun roof, rear drum brakes, 1.6l motor
both the unnamed DX and HF came with a 1.5L motor(D15B2, D15B6)
the Si came with a 1.6L(D16A6)
if your motor has a black box above the intake manifold that says DPFI then you have a DX
if not its either an HF or an Si
but pictures would help much
Just found my title, and checked it against the list posted, and should be a dx. The second set 3 numbers is ED8 which isn't listed? Rear wiper, yes. I'd love to take more pix, but it's out back of the shop, and it's like 25 dergees here in Ohio...
Originally Posted by acmoc
I think 88-89 dx model, the interiors are different
88-89 have orange(amber) bumper lights without the "air ducts" present in the 90-91
90-91 have clear bumper lights, with "air ducts"
I think it's a 88-89 HF
Te corner lenses are 88-89, you can tell by the screws on the side. And the bumper lamps are also 88-89, you can tell by the size, the 88-89 are smaller. I'm thinking it's an HF because the op said he had a 1.6 Li, so the swap would've been more straight foward.
And the antenna mounts are different
DX and si have a metal glossy piece,
hf has a flat black plastic piece.
This is in the FAQ
I was wrong,
This is in the FAQ
This is in the FAQ
you need to learn your CRX body info a bit more, or at least look at a picture of a 88-89 CRX and a 90-91, if you did this earlier you would definitely be able to tell that its a 90-91
and HF's didnt have rear wipers like his does
i think i know since i drive a 91 CRX DX
and doesn't matter if the swap would be more straight forward, any swap is possible
