Help- High idling at normal temps
Old Jul 30, 2002 | 09:06 PM
FlatEric's Avatar
Default Help- High idling at normal temps
My unmodded RS revs to 1.5k rpms when it's been sitting for awhile in a heated garage and pretty much anywhere at normal temps. Anything i can do to change it?
Old Jul 30, 2002 | 09:10 PM
shaun92GSX's Avatar
Default Re: Help- High idling at normal temps (FlatEric)
What year is it? If it is getting older, check your throttle body spring. Then spray some carb cleaner to brak up the **** then spray lithium grease on it.(white ****) see if that helps. Sometimes it will get stuck and won't go all the way down.
Good luck
Old Jul 30, 2002 | 10:23 PM
FlatEric's Avatar
Default Re: Help- High idling at normal temps (shaun92GSX)
I'm a bit of a non savy when it comes to DIU under the hood stuff, the throttle body is the the piece that connects the air hose and the intake manifold, correct? and the wire by there is the throttle cable? It's a 94 btw
[Modified by FlatEric, 7:23 AM 7/31/2002]
Old Jul 30, 2002 | 11:11 PM
vteg's Avatar
New User
Yeah, just remove teh air hose and the throttle plate is inside. Aim for the hinges. You may also want to open it and clean the edges of the plate and the edges of the throttle body.
Old Jul 31, 2002 | 10:29 AM
FlatEric's Avatar
Default Re: Help- High idling at normal temps (vteg)
ok i looked inside and played with the spring, that seems to not be the problem because it goes all the way horizzontal and vertical, someone in another forum said something about a control for cold weather that might not be working, where is that located? Also how do i take the throttle body plate out?
[Modified by FlatEric, 7:29 PM 7/31/2002]
Hi Hater.
17
Oct 18, 2008 10:35 PM
Jeanious
Aug 14, 2007 11:55 AM
obd1_crx
Jun 12, 2007 05:42 AM
smokedyou19
May 10, 2007 05:15 AM
mkinpwrat12g's
Sep 1, 2005 07:12 AM
