crx b16a swap into hf.no place for vtec subharness to plug in
like it says, there is no room for any wires to plug into ecu plug b or c. do i need to take the ones that are there out?
yes u have to take the wires outa the harness just unpin them its easy theres a lil tab u pull outa the hardness and then pull kinda hard on that particular wire and unpin them if your using the hasport harness you also need to just cut or remove wire B9 or your car will not run in reverse and if it does it runs like crap only with hfs it does that
thank you so much.i was wondering why my parts car would run so crappy in reverse.the guy didn't know what he was doing with the previous car.
93egboosted
Mar 18, 2009 07:27 PM
