i changed the head, now battery is draining
Old Jul 30, 2002 | 08:45 PM
LB CRX's Avatar
Default i changed the head, now battery is draining
ok i dont get it....the car was sitting for about a month and finally i changed my head. the car didnt start cuz there was no power so i went ahead and bought a new battery. the first start up was fine...it took a little strength, but it started. the second time it didnt want to start. after a few attempts it started, but i was struggling. what do you think is wrong????
on top of that my car is bogging and im getting a code 6. i messed with the plug a little and i reset the ecu and it still comes on. what the f*ck is going on?????TIA
Old Jul 30, 2002 | 08:51 PM
ExospeedAMcrx's Avatar
Default Re: i changed the head, now battery is draining (LB CRX)
did you put back the ground wire on the right side, near the timing belt area.
it should be connected to the front radiator support/light housing.
Wil
Old Jul 30, 2002 | 08:59 PM
LB CRX's Avatar
Default Re: i changed the head, now battery is draining (exospeedAMcrx)
i know what your talking about....i never had it on in the fist place. im thinking that theres a ground wire that i didnt put on, but its too dark for me to check. any other ideas???????? how bout the grounds that are next to the thermostat? what are those wires charging
Old Jul 30, 2002 | 11:42 PM
kinesistech's Avatar
Even if the ground wasnt there its still important. Add it soon, the other ground for the battery is on the transmission to pasenger side body. Make sure both are good. It wouldn't hurt to check out the plug on the alternator just incase anything happened to it while you were working.
the_dxB16
Sep 5, 2009 09:09 AM
oc_civic
Apr 10, 2008 06:33 PM
petty$rep
Feb 2, 2008 10:25 AM
94PearlWhiteGsr
Oct 15, 2004 07:27 PM
vtec69
Jan 17, 2003 03:30 PM
