are nsx calipers worth it??
Old Nov 10, 2008 | 09:53 AM
umair's Avatar
Default are nsx calipers worth it??
my car needs new pads and rotors(00 si) and i was thinking about doing the nsx caliper upgrade. all i would need is redrilled legend rotors and nsx calipers right?? is the upgrade worth the money??
Old Nov 10, 2008 | 09:57 AM
93egSLEEPER's Avatar
Default Re: are nsx calipers worth it?? (umair)
are you talking about doing a 5 lug conversion too? unless you went 5 lug i would say keep it stock
Old Nov 10, 2008 | 10:30 AM
95vxtealhatch's Avatar
Upgraded calipers are only needed if your running large diameter wheels, or sticky r-compound tires. I have integra spindles on my vx civic and i can lock up fronts with UHP all season Kuhmo ASX tires. So if you always run summer tires or above in combination with 17" rims or larger. you might need an upgraded caliper. Im not sure very familiar with 99-00's, so i don't know if you have to upgrade your rotors to a larger size or not.
I own, like i said, a 95 civic vx (2090lbs) and i put 95 integra ls spindles(rotor and caliper assembly) on. (bye the way all 94-01 non type r integra brakes are the same.) Along with an upgraded master cylinder and im telling ya i can lock my tires up any time i feel like it. Thats just for your information and referance.
Old Nov 10, 2008 | 10:54 AM
90_EX_Civic's Avatar
is it worth it... no it's not worth it. if you are going to track it then yea, but if not then no. the stock breaks on a SI are really good already.
jdmarron
Feb 4, 2016 08:57 AM
Hoodrych1
Suspension & Brakes
Mar 12, 2012 03:20 PM
Jordan_4WS
Oct 24, 2006 01:02 AM
AlienKrOZ
Oct 22, 2004 01:40 PM
VitaminB20
Nov 9, 2002 06:15 PM
