Crx b20 swap
Old Nov 10, 2008 | 09:26 AM
Tensa_Zangetsu's Avatar
Default Crx b20 swap
Can anyone that has done a b20 swap plz tell me how much it will cost with parts and labor. Also it will be helpful to list all the parts i will need so then i can start gathering it. thxs for the contribute.
Old Nov 10, 2008 | 09:51 AM
ThefirstPACT's Avatar
Default Re: Crx b20 swap (Tensa_Zangetsu)
First SEARCH!!!
Second....I just did my swap and I had ALOT of stuff already...trans, mounts, manifolds etc. It still cost me around $1300 for a long block, new clutch and new gaskests/seals.
The information is ALL OVER H-T.
Dutch
Old Nov 10, 2008 | 10:31 AM
can u send me the links and list parts for me if that is possible. thanks
Old Nov 10, 2008 | 10:49 AM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: (Tensa_Zangetsu)
You can't even hit that red search button or click the FAQs and expect to swap a motor?
https://honda-tech.com/zerothread/1508680
You've been spoon fed, you are welcome.
Old Nov 10, 2008 | 11:16 AM
Default Re: (***$nyper)
You actually think he's gonna search in there...lol!
Dutch
Old Nov 10, 2008 | 03:28 PM
lol sorry im not very good at forums as u can tell by the amount of post i have hehe
Old Nov 10, 2008 | 03:30 PM
About the website u gave me. i looked thru it but it didnt talk about any b20 swap on a crx.
Old Nov 10, 2008 | 03:31 PM
dacrxguy's Avatar
would u like us to install it to
well heres the faq https://honda-tech.com/zerothread/1508680 u search through it
Old Nov 16, 2008 | 08:23 PM
why are u sending me the same link as the the other guy. i have searched thru that faq but it dosent have anything relating to the b20 swap under the "B-series swap" it mainly talks about b16 or 18. Im a noob at this swap and not very familiar with crx so right now im desparately in need of help and would like for this crx to start running by end of this december or early jan.
Old Nov 17, 2008 | 03:37 AM
rbwdriven's Avatar
b20 and b16 basically the same swap. like the guys on IA are saying.
need all the same stuff to mount a b20 versus a b16 or b18. Mounts, linkage etc.
Old Nov 18, 2008 | 01:29 PM
Blue-EM1's Avatar
Just did one on mine, and it ran about 500 for the motor, 170ish mounts, 130 hasport linkage, 130 rywire, 100 trans, 30 Teg clutch cable, 320 clutch/pressure plate, 20 dizzy and 90 for the back bracket from Acura and 300 traction bar. so depending out how clean and legit you want to get with it but i would definitely get the traction bar. if you are starting from nothing and dont have any connects with parts expect to pay around 1300 for a good reliable swap! All depends on what you have and how legit you are about it-
Old Nov 18, 2008 | 03:54 PM
oh reallyi thought it was much more based on the info and parts i have gotten im looking at about $1600-$2000. here my list so far:
-Motor : b20b/b20z (choices:hmotor) = $ 750.00
-Tranny:b16/b18 = $ 200-400
-Mounts: (choices: ebay or innovative) = $ 100-200
-Shift Linkage: (choices: Avid) = $ 136.00
-90-93 integra axles and the halfshaft: (choices: Autozone) = $ 130.00
-Intake Manifold: (choices: LS IM or sk2) = $
-OBD1 LS ecu = $ 40.00
-OBD1 LS distributor = $
-dpfi to mpfi conversion harness = $
-OBD0 to OBD1 ECU Conversion Harness = $ 100.00
Total Cost:
be sure to put some inputs if i missed out anything. thanks
Old Nov 18, 2008 | 05:00 PM
blackfoot's Avatar
i jsut did the swap in my car i dont know off hand how much it costed, but i went a little far with it and got everything new, including axles, i picked up a 1990 integra parts car for 300$ for the parts i needed, then had the car sent to the metal recyclers for my money back
motor b20b -500$
transmission - parts car
rear T-braket engine mount - parts car
timing belt cover mount from a obd-0 b18a - parts car
yonaka swap mounts -b-series into EF, - used $100
shift linkage - parts car (modified cut and welded to work)
axles -70$ each new
obd-0 ecu - parts car
obd- 0 dizzy -parts car
i left my car obd-0, i had to run obd-1 injectors, because thats all i had laying around that matched up to an old harness i had, so i cut the plugs off and wired them into my harness that i would be using.. now since i was using obd-1 injectors, they run high impedance.. i had to delete the resistor box, since obd-0 runs low impedance.. so i did that i had to extend my reverse lights wires. my o2 sensor plug, my water temperature plug and add the plug on the end. my intake manifold. the place where the IAT belongs was casted over from factory.. so i had to drill into my intake pipe and plug the iat there. and i extended the wires to that plug
i know ive spent more than 2grand, with little odds and ends. but just cant remember everything
Old Nov 19, 2008 | 08:28 PM
motor b20b -500$
axles -70$ each new
what about your conversion from dpfi to mpfi. where you bought it at and how much u got it for?
Old Nov 26, 2008 | 11:42 AM
bump plz
Old Nov 26, 2008 | 01:13 PM
My_EFsedan's Avatar
i wait for good deals to come around. i just got done with a swap for my cousins ef. LS motor (same components used for b20/b16 etc) we got lucky cause it was a low mileage integra for $450. after messing with the car and finding out it had bondo everywhere!! we parted it out. so we got the LS motor with tranny, axles, halfshaft, ecu, harness for mpfi, basically everything to swap. even rear disc brakes and what not. sold everything and got money back so swap was free to us.
-i get b20s for $450 delivered to my door local
-i bought mounts for 6 bucks Bseries to EF from the junkyard but normally could get them for $100 bucks (recently sold hasport mounts and linkage for $200 )
-shift linkage, you can do the ghetto cut and weld which works fine but you have to cut and weld at the right spot or it will have hella play in it when in gear. but new can range from $130-$150
-axles, eh autozone. $140 for 2 new lifetime warranty
-halfshaft and misc from the junkyard which doesnt cost too much.
-dpfi>mpfi i do myself, fairly easy now. (as 0bd0)
-tranny i got b16's from $250-350
-basic Exedy clutch kit for $225
-ecu 0bd0 would go real cheap on craigslist some sell for alot
-manifold, pick one out at the junkyard, wait for it on craigslist or just get a blox one since junkyard is $-100-$130
-dizzy
you get the idea. i could spend no more than $1000 on a swap. i just wait for good deals to come around and hop on it.
depends how fast you want it in. you can pay what ever the price others are asking and get it done or wait it off if your not in a rush to do the swap. get everything together then swap. so you do not have to run around finding parts and you car just sits.
thats what i did.
Old Nov 26, 2008 | 01:53 PM
woah u sure have a hell of a deal! but then again what kind of b20b you got? it comes in three different type of compressions. i got the high compression one which is y it cost me alot plus of shipping. but then again thxs for the info.
Old Nov 26, 2008 | 02:22 PM
redsolturbo's Avatar
save yourself the trouble and get the cheapest decent b20 you can and shove some r.s machine pistons or YCP ones in it. wont be long before you want higher lift cams and it will benefit loads from the compression increase, also means you will have plenty of valve to piston clearance.
(on a side note -is it just me or was this weeks bleach episode crap?)
Old Nov 26, 2008 | 02:50 PM
well u see i already ordered the high compression one on hmotoronline. And this will be mostly my dd car. So it will be a while till i do anything special to the car after the swap (no money).
Yea this week bleach does sucks. Luckily i read the manga so i know wats up
Old Nov 26, 2008 | 05:53 PM
My_EFsedan's Avatar
i had a 96 crv b20b. the Zs i cannot get cause they always say "we dont have them anymore" depends what they have i'd scoop the better one
95.5-98 JDM B20B are 8.8:1 p3f compression pistons
Rated at 126hp
https://honda-tech.com/forums/tech-misc-15/difference-compression-between-b20b-vs-b20z-460954/
Old Nov 27, 2008 | 10:39 AM
ZC1.8crx's Avatar
search here www.b20vtec.com
Old Nov 29, 2008 | 10:07 PM
I also got another question. Will getting a b series speed sensor work for all b series trany?
Old Mar 21, 2011 | 02:19 PM
Rexer23's Avatar
I have a 88 Crx si shell..im dropping in a b20z with a b16 head..im running it with obd1 will a Gsr Tranny be better or should I go with a b16 Tranny?
ThatGuy89
Feb 26, 2009 04:33 PM
nelsonb16
11
Sep 24, 2007 03:45 AM
ap1$2k
Jul 17, 2007 11:04 AM
eg6blkk20
Jul 6, 2007 01:32 PM
B-serious
Aug 27, 2005 09:19 PM
