Automatic transmission acting odd
Old Nov 10, 2008 | 07:49 AM
4g63powered's Avatar
Default Automatic transmission acting odd [resolved]
First off; it's my DD, so no "do a manual swap."
The car is a 98 LS automatic, has ~70k on it. Recently it has been shifting a little odd; namely on the highway it seems like the torque converter will randomly lock and unlock. It does it while traveling at a constant speed on level ground, so the load is not changing.
Is this typical behavior for an automatic honda? Is there a separate computer for the transmission that might be on the fritz?
TIA
Modified by 4g63powered at 1:02 PM 11/14/2008
Old Nov 10, 2008 | 09:32 AM
AWD Terror's Avatar
Default Re: Automatic transmission acting odd (4g63powered)
Honda has been known for having issues with their automatic transmissions. Not to the point of Dodge however.
The absolute first thing to do when you are having transmission troubles is change the fluid. People rarely ever change the fluid, and many problems can be avioded by doing this.
Old Nov 10, 2008 | 11:11 AM
deftonerider's Avatar
if that don't work then change the transmission. at acura damn near anytime that the car throws a hydralic or mechanical tranny code the replace the transmission
Old Nov 14, 2008 | 03:15 AM
Got the transmission flushed last night, and it seems to have done the trick.
Old Nov 14, 2008 | 06:25 AM
AWD Terror's Avatar
Default Re: (4g63powered)
Just keep an eye on it. Sometimes flushing the tranny is just a temp fix.
Good Luck
Old Nov 14, 2008 | 07:45 AM
Default Re: (AWD Terror)
Good Luck
Fingers are already crossed.
imbest123
Feb 6, 2012 04:49 PM
trevorjohn88ef
Transmission & Drivetrain
Nov 5, 2009 08:42 PM
Linh.
Feb 13, 2008 04:07 PM
mynameizstitch
Apr 26, 2007 09:07 AM
DraginTeg93
Dec 14, 2006 02:53 PM
