OBDII dizzy to OBDI harness wiring?
mini me swap in a 94 eg (OBDI) now has a d16y8 head (OBDII) need either wiring schematics to swap dizzy plugs or need someone who sells an adapter. previously took two dizzys to make one, OBDI dizzy crapped out on me. need help fast!
the only difference in the two harness's is that the obd1 has 2 with one being the small 2 prong that has the black/yellow and blue wire. With obd2 that small 2 prong connector is integrated with the big one, so just find the wires and put them together.
rywire can make you a jumper harness for $25
http://www.rywire.com
Originally Posted by ABK
or you could swap the guts or make your own harness.
live2tune4cvd
May 8, 2007 12:06 PM
