93 integra auto to 5 speed swap need help
Old Nov 9, 2008 | 05:56 PM
kenneth4g4d's Avatar
Default 93 integra auto to 5 speed swap need help
Im convertin my 93 integra gs auto to a 5 speed. I got a 5 speed tranny but im not sure on all else i need. I know i need shift linkage and clutch and brake pedal. What else to i need??
Old Nov 9, 2008 | 06:45 PM
majinsoftware's Avatar
flywheel,clutch,pressure plate,gearbox,front gearbox mount,clutch cable/hydro setup (depending what way you go),shifter,shifter linkage,
pedal box,ecu,manual cam,manual dash faceplate(To hide the auto lights)
You can skip some of these things like faceplate,ecu and cams but its best to do them to get the car running like a full manual then a auto with manual box.
Also lots of auto wiring and controls under the dash you can bin.
Old Nov 9, 2008 | 08:55 PM
Default Re: (majinsoftware)
so can i use my auto ecu or do i have to change it ?
Old Nov 9, 2008 | 09:10 PM
You can use it but your power will be down compared to a manual ecu, and it might throw a error for missing auto solenoids.
Atleast mine did error 19 I think cant remember and cant be bothred looking it up but the error didnt affect anything, vtec and everything still worked.
And there will be 2 auto control boxs under the dash, One for the reverse lights and dingle thing.
and another one for gear selecting.
you can leave them in but I removed them due them being useless on a manual and just adding weight and unneeded power usage.
Might be different in a 93 tho.
Happy 100 posts to me :D
Old Nov 9, 2008 | 09:49 PM
iight thanks and looks like itll be way easier than i was told lol
Old Nov 9, 2008 | 09:54 PM
also may need to cut hole in the firewall for the clutch but not 100% with 93 gs, if auto was the option instead of manual being the option then it will be pre cut.
slowDB7
Feb 25, 2013 07:43 AM
qcty_jdmes1
Honda Civic (2001 - 2005)
Oct 15, 2009 02:41 PM
DBG0823
10
Feb 6, 2009 09:03 AM
uenolove
Feb 27, 2008 04:32 PM
