F/S: Complete (and I mean COMPLETE) Turbo Kit + Misc turbo related items
My motor's done for so I'm parting it out.
1) Complete turbo kit... made a baseline of 233whp 181trq off the 7psi spring, and 308whp 239trq on 14psi with a STOCK LS motor on RedZone's dyno tune.
- Spoolin' Performance log manifold (Non-AC). Re-braced by Phil 4 months ago.
- Spoolin' Performance dump tube
- Spoolin' Performance 3" downpipe (big dent on it, but I got it that way).
- Tial 38mm waste-gate with 7lb spring
- Garrett T3 57Trim turbo (normal shaft play)
- Turbo cone filter
- Oil return line, feed line, feed line "T", and restrictor
- Drag GenIII FMIC
- Drag GenIII charge pipes (has GReddy CARB# badge)
- HKS SSQ BOV
- Pipe clamps and couplers
- Vacuum lines
- DSM 450cc injectors
- Resistor box
Asking $1400 obo for the above. - SOLD!
Other turbo related stuff are:
2) DP-back 3" full exhaust mandrel bent/welded with 3" Magnaflow muffler for 2dr 94-01 Integras.
- $260 - SOLD!
3) OEM 92-95 Civic radiator with pusher slim fan (OEM Plug on fan wiring)
- $60 - SOLD!
4) Turbonetics MBC (Manual boost controller) with fittings and mount bracket
- $50
5) 96-01 LS/B20 sparkplug cover (Chameleon painted, can easily be stripped to original aluminum finish) - One mount fitting stripped, but still mountable.
- $60
6) Blox Intake manifold for LS/B20 heads
- $130 - SOLD!
7) Power+Plus 65mm throttlebody for ITR/LS manifold style applications
- $120
8) GM 3bar MAP sensor with pigtail harness
- $60
Everything is still in the car! Haven't taken anything off yet.
<U>TRADES</U> I'm interested in are:
- Virgin/Socketed P72 or P28 ECU
- Tial 44mm V-band wastegate
- EBC
- 1000cc injectors (ones that don't require resistor box, if it exists)
- B16/ITR Edelbrock Victor-X manifold
- 70mm Blox Throttlebody (or any brand)
Bump if you have viewed, or are interested in something
Modified by DC4KiD at 8:03 PM 11/16/2008
- Turbo cone filter
- Drag GenIII FMIC
- HKS SSQ BOV
- Vacuum lines
- Resistor box
- $260 - SOLD!
- $60 - SOLD!
- $50
- $60
- $130 - SOLD!
- $120
- $60
- EBC
Originally Posted by DownDC2
I got a blox 70mm tb with new gaskets and a virgin p28 ecu if u wanna buy. $250 for both.
Originally Posted by civic efb16
bump for you should have said wsup if u saw me at dnbs LoL
GM 3bar map sensor added!
Didn't think ppl want this kit that bad, Lol. You're third in line for the kit.
Originally Posted by soontobeboost
sell it to me! like i asked you to!!!!!!!
Originally Posted by n*werk
question.. did you make that power on race gas?? power curve is way to smooth for 91 oct...
