90 honda accord jerks very bad when put in reverse or when gear changes
hello Guys.
i have a 90 honda accord ex and it jerks very badly whenever i start the engine and put it in reverse. Is it because of the torque converter is bad or the rear engine mount, or is it the whole transmission. need some help on this topic fellows. Any kind of help is appreciated.
i would check the motor mounts first....its the easiest thing to do...if all look good...u can cross that out ur list....
What is the RPM when you shift into gear?
The rear motor mount has a vacum control system and a small linkage on the back of the mount; be sure the metal link bar is still hooked up.
Kabato48
Dec 16, 2008 07:19 PM
bluskye
Mar 11, 2006 04:04 PM
tjd92accord
Nov 6, 2005 03:07 PM
