part list ?
Old Nov 9, 2008 | 11:54 AM
waynecoSI's Avatar
Default part list ?
ok, my question is simple and i have searched but i cant find what im looking for so i just figured i would post.
Im doing an ls swap with gsr tranny in my ek. I just need to know basicaly what mounts to use/ brackets. can i use the integra mounts and brackets?
I read that i use the civic harness.( Does it have to be an EX?) Flame me all you want, i just suck at searching
Old Nov 9, 2008 | 11:59 AM
slo_hatch's Avatar
Default Re: part list ? (waynecoSI)
you will need integra mounts, your wiring harness should work (since your not using vtec), and you will need the shift linkage from a civic si or integra, and b series axles. i believe thats all you need. if i forgot somethin someone chime in.
Old Nov 9, 2008 | 12:02 PM
waynecoSI's Avatar
Default Re: part list ? (slo_hatch)
thanks for the quick response!
Old Nov 9, 2008 | 08:55 PM
lee97ex's Avatar
http://kosmo.homedns.org/trey/6gen/
this site has some really good info about b-series swaps, you are also going to need a radiator that is compatible with the 99-00 SI because the ports on the b-series are bigger. I'll keep looking around to see what other info I can piece together
Old Nov 9, 2008 | 08:56 PM
lee97ex's Avatar
Default Re: part list ? (lee97ex)
ps. if the link doesn't work when you click on it just copy and paste i guess cause its good
Old Nov 9, 2008 | 10:48 PM
mattyv's Avatar
u need b16 engin bracket for drives side that attatches to the actual mount and a b16 rear T bracket also
Old Nov 10, 2008 | 07:48 AM
waynecoSI's Avatar
Default Re: (mattyv)
thanks
teamrpm2
15
Apr 26, 2008 07:14 PM
kcjohnnyboy
Feb 23, 2006 10:50 PM
TRDSUPRAT88
16
Jun 16, 2004 08:11 PM
b18cInside
Dec 10, 2002 09:02 AM
b18cInside
Dec 8, 2002 11:48 PM
