Shop closed everything must go!!!
I have some remaining inventory from a shop that recently closed, I am only interested in selling all the remaining parts or bulk orders. There is a mixture of stuff for all types of cars, not just hondas. The parts list includes part numbers and a brief discription, but if you have any questions about the parts please ask. I still have 2 or three boxes of things to go through so I will be adding parts to the list as I get it done. This stuff is perfect for a current shop, or someone that has time to sell online. Please PM me with any questions or email at airmayo@hotmail.com I will post pics shortly
Vortech
5A001-121 Split Second tuning box
Vortech 8H100-002 oil inlet filter kit fox body mustang
Edelbrock
8036 Chevy Throttle Bracket
8009 Chevy Cab adt.
8018 Trans Kick down
Centerforce
016 Throw Out Bearing
210 Throwout Bearing
820 Throwout Bearing
Crane Cams
99002-1 Assembly Lube
Moroso
(3) 9050 Fire Wall Grommets
74103 Battery Terminal
65310 Fuel gauge fitting
72920 Spark plug index washers
26140 distributor gear shims
73235 coil wire set
MSD
8070 Ford distributor rotor
Crower
87028-20 Honda Retainers
Taylor
45961 409 repair
74244 8mm spiro Pro Wires
Mitsubishi
M04648619 Sealed Valve Stems (set)
Spectre
S901 Fuel Pressure Gauge
42283 Alternator Bracket
4950 Air cleaner adapter kit riser
4806 Air Filter
4790 Air Cleaner
42353 Timing Chain cover
4809 Air Filter
3368 Magna Clamp
4510 Coil Bracket
4520 Ignition Coil Bracket
5324 Valve Cover Tabs
42273 Alternator Bracket
5478 Magnet Oil Drain Plug
4616 Race Car Wire Loom
5320 Valve Cover hold downs
(2) 5321 Valve Cover Spreader Bars
4213 Air Cleaner Stud Kit
1418 Bolt Caps
3368 Hose end clamp
45583 Wire loom
5773 Carburetor adapter kit
42493 Fuel Pump Mounting Plate
2418 throttle cable bracket
46703 Header bolt set
4320 Oil Cap
3368 hose end clamp
42463 fuel pump block off kit
5772 Carburetor adapter kit
4604 Wire Looms
4209 Air cleaner nut
4254 Racing wire separators
5298 Valve Cover hold downs
5760 Distributor clamp
2408 Power Valve Saver
2484 PCV Valve Breather
4606 Wire separators
4601 wire separators
2428 throttle cable Bracket
4237 timing tab
680 holly gasket kit
4592 pro wire looms
4602 wire separators
5754 advance curve kit
1848 Wire looms
2517 Fuel Pressure Regulator
4257 hood pin kit
4596 pro wire looms
5320 Valve cover hold downs
5298 Valve cover hold downs
5946 hose fittings
42523 Carburetor studs
2369 universal fuel filter
4239 wire spreaders
4280 push on breather
4300 push on breather
4281 twist on breather
4226 Alternator bracket
4518 coil covers
18483 slider wire dividers
45683 wire loom
4594 wire loom
5378 heater hose support bracket
46523 intake manifold bolts
46533 Intake manifold bolt set
3368 hose end clamp
3160 hose end clamp
4481 alternator fan assembly
4310 oil filter cap
5478 magnetic oil drain plug
54383 wire loom
1698 vacuum advance cover
4480 fan pulley shim kit
4675 collector bolt set
42473 fuel pump block off kit
1798 power steering dipstick
1738 oil filter plug
60183 plug set
4708 throttle spring bracket
4279 push in breather
2359 replacement filter
4612 wire loom
4614 wire looms
45483 wire loom
4338 radiator cap
21000 injector o ring seals
Stant
59359 Thermostat
(2) 11234 Radiator Cap
Professional Products
(2) 10204 Barb fuel filter
10205 Barb fuel filter
10242 Fittings
10234 Fittings
Victorreinz
K3158 Water Pump Gasket
Accel
130224 Rotor
7040 Race Plug Wires
9001 Extreme 9000 wire set
Pioneer
TS164P Speakers
Ford
Fox Body Door Weather Stripping
True Flow
95110 Filter service kit
Hays
70110 Throwout Bearing
70115 Throwout Bearing
Fram
(2) SD-2 Sure Drain
Nokya
3157 Bulb
Autometer
20405 Honda Accord Gauge Pod
20440 Honda Prelude Gauge Pod
3214 Red boot light covers
PIAA
7443 Bulb Set
APC
9004 HB1 bulb
Toucan
(2) 9005LXC 9005 Bulb set
Pro 5.0
Crome Shift **** Ford
AmPro
T70046 Spring lock coupling tool ford
Nissan
8407 Fuel Adapter Fitting
Holly
2613
OEM
25042 A/C and Fuel line disconnect tool
Ford Racing
(2) M-12297-R04 Spark Plug Wire divider
(4) M-12297-B03 Spark Plug Wire divider
Autoworks
AT-509FD Car Stereo inhalation kit ford/mercury
MSD
2400 Weather tight connector
March
00630 SB ford serpentine pulley kit
Vortech
Edelbrock
8009 Chevy Cab adt.
Centerforce
Crane Cams
Moroso
73235 coil wire set
MSD
Crower
Taylor
45961 409 repair
Mitsubishi
Spectre
4806 Air Filter
4790 Air Cleaner
4809 Air Filter
3368 Magna Clamp
4510 Coil Bracket
1418 Bolt Caps
3368 Hose end clamp
45583 Wire loom
4320 Oil Cap
3368 hose end clamp
4604 Wire Looms
4237 timing tab
4592 pro wire looms
1848 Wire looms
4257 hood pin kit
4596 pro wire looms
5946 hose fittings
4239 wire spreaders
4518 coil covers
45683 wire loom
4594 wire loom
3368 hose end clamp
3160 hose end clamp
4310 oil filter cap
54383 wire loom
60183 plug set
4612 wire loom
4614 wire looms
45483 wire loom
4338 radiator cap
Stant
59359 Thermostat
10242 Fittings
10234 Fittings
Victorreinz
Accel
130224 Rotor
Pioneer
TS164P Speakers
Ford
True Flow
Hays
Fram
(2) SD-2 Sure Drain
Nokya
3157 Bulb
Autometer
PIAA
7443 Bulb Set
APC
9004 HB1 bulb
Toucan
Pro 5.0
AmPro
Nissan
Holly
2613
OEM
Ford Racing
Autoworks
MSD
March
raverx3m
Welding / Fabrication
Jan 18, 2013 03:54 AM
TheSauceSpot
22
Mar 31, 2011 05:26 PM
shortyz
Jan 8, 2003 04:04 PM
