gc spring rates
Old Nov 8, 2008 | 07:43 PM
twiztid00002's Avatar
Default gc spring rates
im going to order ground controls monday. they are gonna be matched up with stock struts(5th gen) and i dont want to blow the stut so whats a good spring rate to get for a daily driver?
and does anyone have the pic of how to cut the bump stop and how to set it up..its like a diagram. kronn98 posted it before, cant find it tho
thanks
Modified by twiztid00002 at 10:42 AM 11/9/2008
Old Nov 8, 2008 | 07:48 PM
dagle's Avatar
Default Re: gc spring rates (twiztid00002)
i have GC's on stock struts, i would suggest against it unless if you're only to lower like 1-1.5". it's better in the long run to have just ordered strut and spring together or even a full coilover.
Old Nov 8, 2008 | 07:54 PM
Default Re: gc spring rates (dagle)
why?
and eventually wen i get some more cash ima get agx's probly to match em up with
Old Nov 9, 2008 | 10:09 AM
Kronn 98SH's Avatar
I basically have the same question, because I bought some off-the-shelf GCs and they are way too soft. Anyone know what the factory spring rates are for them?
Old Nov 9, 2008 | 10:19 AM
Default Re: gc spring rates (Kronn 98SH)
NirVTEC said: GC OTS is 380F/275R
Old Nov 9, 2008 | 10:20 AM
Kronn 98SH's Avatar
Based on that, I would guess that 450F/400R would be the way to go for me. I like highspeed turns without body-roll.
Old Nov 9, 2008 | 10:30 AM
yea same here. and kronn98, u posted a diagram before on how to cut bump stops and stuff on the stock shock wen putting on a coilover. can u find that again please.
and also nolimitmotorsport.com can do spring rates so u dont have to get them over gc website. there like 75 dollars cheaper
Old Nov 9, 2008 | 12:17 PM
Kronn 98SH's Avatar
I searched for 30 minutes and couldn't find the original thread, maybe someone else is familiar with it. But here is the diagram: (front and rear are the exact same minus the O-rings)
Old Nov 9, 2008 | 12:22 PM
thanks man
uses0ap
Jul 4, 2009 07:44 AM
pjr710
Suspension & Brakes
19
Apr 19, 2007 02:44 PM
MinimalXistance
Suspension & Brakes
Feb 11, 2006 05:19 PM
JapSpec954
Jun 13, 2003 02:44 PM
Soulless
10
Dec 16, 2002 01:57 PM
