Proper D-bar location and positioning??!!??
Old Nov 8, 2008 | 06:28 PM
boostedhfrex's Avatar
Default Proper D-bar location and positioning??!!??
Can you guys post pics of how your "d-bars" are mounted on your NHRA approved cages. At this point is it still legal to run a bar across the floor for the d-bars to attach to? In my case I'm 6'3 280lbs, so I need as much room as possible so I have the main hoop mocked up on the upper tray (most people mount them on the lower floor behind the seats). If anyone could post some pics if they have a similar setup that would help us out alot. Here's some pics of how it is currently mocked up. Disregard how the d-bars are currently sitting in there, the guy welding the cage wasn't sure on how they should be mounted on a unibody car so we already know they aren't correct
Old Nov 8, 2008 | 07:05 PM
nonvtecallmotor's Avatar
Default Re: Proper D-bar location and positioning??!!?? (boostedhfrex)
There has to be a bar that run rocker panel to rocker panel then the D-bars connect to that bar.
Old Nov 8, 2008 | 07:18 PM
Default Re: Proper D-bar location and positioning??!!?? (nonvtecallmotor)
So will that main hoop not work where it is currently located? Then it seems like the d-bars would be angled forward. Thanks for the info
Old Nov 8, 2008 | 07:59 PM
SPOOLINmatt's Avatar
this is still yet to be 100% clarified. In the rule additions it says "if blah blah blah, than d bars MAY be attached to rocker bar"
I don't think it is TECHNICALLY a rule........yet
Old Nov 9, 2008 | 02:14 AM
Default Re: Proper D-bar location and positioning??!!?? (SPOOLINmatt)
Gotcha, so are rocker bars 100% required even if I'm not running a d-bar down to them?
Old Nov 9, 2008 | 10:40 AM
rip94delsol's Avatar
I had a rocker bar setup and my cage was passed without d-bars. But me being who I asked my fabricator to install d-bars.
let me tell you that I had my cage inspected at NHRA and not just a regular inspector.
Old Nov 9, 2008 | 10:43 AM
Default Re: Proper D-bar location and positioning??!!?? (rip94delsol)
i think its one or the other type of deal. I've seen cages with just D-bars get passed though. The techs at NHRA believe that D-bars will perform better that a rocker setup.
I remember the fabricator and the inspector having a discussion about it.
Take it to them and see what they say.
Old Nov 10, 2008 | 07:25 AM
thanks for the info and insight
acrocat
Suspension & Brakes
May 3, 2007 08:20 PM
IGGY
Mar 9, 2005 07:36 AM
909vteckiller
Oct 2, 2004 07:51 AM
Burke
Feb 5, 2004 06:03 AM
arw321
Oct 16, 2002 03:26 PM
