How to ADD cruise control in 00 EK w/ type R motor and JDM ECU
Old Nov 8, 2008 | 03:22 PM
ben1284's Avatar
Default How to ADD cruise control in 00 EK w/ type R motor and JDM ECU
I have a DX 2000 EK hatch with JDM ECU and type r motor. Is it possible somehow to add a cruise control ???
Old Nov 8, 2008 | 06:18 PM
RyanA's Avatar
Default Re: How to ADD cruise control in 00 EK w/ type R motor and JDM ECU (ben1284)
Yep. Same way you'd add it if your car was bone stock. Same way you'd add it if it had a big block Chevy, too. Find a CC harness diagram and get all the parts you need to do the swap. Clutch switch, brake switch, activation switch, clockspring, steering wheel controls, cruise activation button, cruise module, cruise actuator with cable, and pedal assembly. Wire it all up and you are set!
Ryan
Old Nov 8, 2008 | 06:23 PM
Eran's Avatar
HT White Ops
Default FV-QR
Don't forget the dash harness with the cluster and button plug.
BIGthings
Mar 1, 2007 01:09 AM
Dr. Willy
Feb 12, 2007 10:08 PM
dc2.itr
Feb 13, 2006 05:45 PM
nurvcom..
Oct 9, 2005 06:38 AM
