Rod bushings
Old Jul 30, 2002 | 05:29 PM
00civicvtec's Avatar
Default Rod bushings
Where do you get the rod bushings to fit LS rods onto D16 pistons, I called up the machine shops and they said that I must supply the bushings.
Old Jul 30, 2002 | 07:47 PM
earl's Avatar
Default Re: Rod bushings (00civicvtec)
I could be wrong on this one but I don't think the stock ls rod uses a bushing unless you were going to make it full floating. I believe it's just a matter of press fitting the pin into the piston and rod.
If you do need the bushings because of pin size diff between the B and D motors, try calling Crower for them.
Old Jul 30, 2002 | 09:09 PM
Default Re: Rod bushings (earl)
There's a pic of the LS rods, looks like there are no bushings....the pin on the LS piston is bigger than the pin on the D16 piston, so the small end must be reduced in size to fit...
Someone help me out
Old Jul 30, 2002 | 10:11 PM
earl's Avatar
I get bushings for B series crower rods from crower, so try them first.
Old Jul 31, 2002 | 10:12 AM
Thanks Earl, I talked to Brian Crower and he said he could get me the bushings for $8/ea.
Problem solved
Doc1020
Jul 28, 2014 05:48 AM
Red_ED8
19
Aug 15, 2010 04:14 PM
