Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
civic 06 headlight qs
Old Nov 8, 2008 | 09:42 AM
boyce1118's Avatar
New User
Default civic 06 headlight qs
hi all
i almost know nth about cars, so if i ask any silly qs plz dont mind-0-''
i jsut grab a civic 06 lx, and i wanna to install a led sth like 8000k lightbulb for it, i wonder wt kinda of thing i need to buy? the bulbs, if it will already associated with a transformer? also, if that i should buy diff pair of bulbs for high beam and low beam or the bulbs will fit for both?...
thz alot^^"
Old Nov 11, 2008 | 02:30 PM
boyce1118's Avatar
New User
Default Re: civic 06 headlight qs (boyce1118)
i just call the body shop...they said they will charge $2xx for the HID conversion kit installation...(i guess i did explain well wt i need to them..)
and the Honda Manufacture says will charge only $32 for the installation...
i wonder if anyone knows anywhere will be cheaper or $32 is already a reasonable charge?..
thz~~
Old Nov 11, 2008 | 07:48 PM
Greg50Lt's Avatar
if you want a HID kit then you need to be a kit which is a ballast or 2 ballast and the bulbs and wiring. then you need to hook them up. You can get a "fake" HID bulb that you just replace your OEM bulb with. The last option which is the best but most expensive is to get a retrofit projector kit done. Customlightz.com does them.
rawrjaay
Lighting
19
Nov 27, 2010 11:05 PM
sealtima
Aug 14, 2008 07:00 AM
dlprince
Honda Civic (2001 - 2005)
19
Jun 29, 2007 07:10 AM
2005 TSX
Apr 5, 2006 01:12 PM
Mr.DC2TurBo
Mar 9, 2003 02:24 PM
