Suspension & Brakes Theory, alignment, spring rates....
Negative Wheel Angle issue. Help and Suggestions Please.
Old Nov 7, 2008 | 04:36 PM
Lil Gnome's Avatar
Default Negative Wheel Angle issue. Help and Suggestions Please.
I have a 1996 Honda Civic DX Four Door. As for the shocks and spring, i have no idea. So rice one I bought with the car. Normal ride height, but WAS lowered about 2 in. Tie rod came loose once. Just a history report about what I've experienced with this car.
But the problem is, my front left tire is tilted into the wheel well. Negative camber angle. And I have NOO idea why? If you need pics. Tell me.
Old Nov 7, 2008 | 05:41 PM
PIC Performance's Avatar
Default Re: Negative Wheel Angle issue. Help and Suggestions Please. (Lil Gnome)
Does the car have aftermarket front upper control arms? If you don't know or cannot tell, jack the nose up and let the suspension droop down, so that you can get a good, clear shot of the inside of the wheel well. Some people put aftermarket upper control arms in the cars to add or subtract camber.
If you know the car doesn't have something like that, then something is bent. Has the car ever been in an accident?
Old Nov 7, 2008 | 06:54 PM
Lil Gnome's Avatar
Default Re: Negative Wheel Angle issue. Help and Suggestions Please. (PIC Performance)
The shocks and springs are the only thing not OEM. And tomorrow, I will jack it up to check it out.
Old Nov 8, 2008 | 01:31 PM
Lil Gnome's Avatar
bump
Old Nov 8, 2008 | 01:52 PM
Lil Gnome's Avatar
Here are some pics of my car.
Old Nov 8, 2008 | 02:08 PM
cruizinmax's Avatar
Thats not the original left front knuckle I don't think. Look at the top by the ball joint.
Lil Gnome's Avatar
I no idea why I posted the right side of the car... Damn.
Old Nov 8, 2008 | 08:59 PM
Psychoteen101's Avatar
wow, thats definately some major camber. which its even wierder cause its that bad with the car jacked up, cant imagine how bad it gets when the car is on the ground with weight on it. Does the hub bearing have play in it?
Old Nov 9, 2008 | 01:15 AM
xd69's Avatar
Default Re: (Psychoteen101)
Good thing you posted the other side, it gives us the chance to tell you whats wrong with the car.
It is your knuckle, it is for 17+ year old civics
This is what its supposed to look like:
Which is how any EK/DC/EG knuckle looks like
This however:
Last time i saw one of those was in a 88 civic 4wd!!
Old Nov 9, 2008 | 01:09 PM
Lil Gnome's Avatar
Idk if it would... But when I used to drive, it would pull SO HARD to the right. So going str8, I would have the steering wheel half way turned to the life to counter it. And while parking, when I would turn the wheel are the way to the right, and would like, drop to the right really hard. So when I went back to the left I would have to turn it with extra effort to get it out of that lock...
Old Nov 9, 2008 | 07:21 PM
hayabusa160's Avatar
Default Re: (Lil Gnome)
get the right kunckle and you will be ok.
Old Nov 9, 2008 | 09:28 PM
Lil Gnome's Avatar
Default Re: (hayabusa160)
Thanks for the advice, but I wanna ask, what makes you so sure that I need that? Just so I can look for the same thing if this issue so happens comes up again.
Old Nov 12, 2008 | 08:49 AM
Lil Gnome's Avatar
Bump. Help plz.
Old Nov 12, 2008 | 11:52 AM
simple. the steering geometry on the older civics pre 92 are not the same.
thats why you cant just swap the 5 lug set up off an itr on the da and ef cars. the steering will get all messed up.
Old Nov 12, 2008 | 06:12 PM
Targa250R's Avatar
be professional
Originally Posted by Lil Gnome
Bump. Help plz.
They've helped you already. I spotted the same thing immediately when I opened this thread - your left steering knuckle is not the correct piece for the car.
The brake calipers are even different. The knuckle on the left side looks like it may be from a '90-91 CRX Si, judging by what appears to be a Nissin 16CL13VN caliper. Edit: Upon closer inspection, looks like it's from a '90-93 Integra or '90-91 Civic EX because it has a 10.3" rotor on that side compared to the 9.6" rotor on the right side. Caliper is a 17CL14VN, not a 16CL13VN - you can tell by the shape of the pad backing plate. If you tried to replace your front brake pads or rotors, you'd find that you couldn't use the same parts on both sides!
'88-91 Civics had different suspension geometries from '92 and later models; that's why the alignment is so far off.
Modified by Targa250R at 10:23 PM 11/12/2008
Old Nov 12, 2008 | 06:14 PM
Targa250R's Avatar
be professional
By the way, you'll also want to pick up some tires that aren't bald, and it would be a great idea to get OEM-type lug nuts to replace those tuner lug nuts.
That car has definitely had a hard life, judging by the body damage up front, the tire rub marks in the wheel wells, and the missing spash shields.
Old Nov 12, 2008 | 06:49 PM
Lil Gnome's Avatar
Default Re: Negative Wheel Angle issue. Help and Suggestions Please. (Targa250R)
I have OEM lugs, and I've been trying to get new tires. But I needed to get this problem repaired. Thank you man.
Old Nov 14, 2008 | 11:07 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
haha my buddy once put a DA Integra knuckle on his EK hatch, on the same side as on your car! The knuckle itself is taller than EK knuckles, which makes the upper control arm tilt up farther, causing the major negative camber on that side.
Old Nov 14, 2008 | 05:52 PM
Ya Digg's Avatar
Default Re: (PatrickGSR94)
time to fix it
Honda knowledge
Apr 15, 2015 10:41 AM
whiskaz
Jun 20, 2009 06:56 PM
pdotjones
Dec 19, 2006 10:02 PM
rudeman85
Oct 28, 2004 03:34 PM
RockDawg_GSR
Nov 30, 2002 05:28 PM
