95 accord ex
Old Nov 7, 2008 | 01:53 PM
rbarrett's Avatar
Default 95 accord ex
Ok here is my problem. I have what sounds like a rod knocking at 2000-2200 rpms no noise before that or after that rpm. Put new rod and main bearings and it makes the same sound and at the same rpms. I can turn the dist. and slow the timing down and the knock range changes a few hundred rpms but is still there. Another issue it seems to only knock after the the oil gets warm. After the oil gets warm the cel light comes on, thats when i notice the knock. When i try to check the cel codes there are none. Everytime that I turn the car off and back on the cel is off and only comes on when the car heats up. The speedo does not work and have re-placed the speed sensor and it still does not work. Would the light come on because of the speedo and as long as i am not moving it stays off? Thanks for anty help
Braden Bullard
Mar 12, 2019 02:53 PM
wips310
Apr 30, 2008 04:33 PM
Mike36
Dec 18, 2006 08:19 PM
keepinitsimple
14
Nov 7, 2004 10:28 PM
12thstreetjunkman
Mar 29, 2004 11:04 AM
