obd1 Vtec/nonvtec distributor question
Old Nov 7, 2008 | 08:33 AM
Damills's Avatar
Default obd1 Vtec/nonvtec distributor question
I have 88 civic converted to obd1 with b18 in right now. I am running obd1 LS distributor. I want to swap out the b18 and drop in a b16. Question is do I need a Vtec obd1 distributor with the b16 or can I use the b18 dizzy on it.
Old Nov 7, 2008 | 10:21 AM
EJ1 LS guy's Avatar
Default Re: obd1 Vtec/nonvtec distributor question (Damills)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Damills &raquo;</TD></TR><TR><TD CLASS="quote">I have 88 civic converted to obd1 with b18 in right now. I am running obd1 LS distributor. I want to swap out the b18 and drop in a b16. Question is do I need a Vtec obd1 distributor with the b16 or can I use the b18 dizzy on it. </TD></TR></TABLE>
nope...not gonna be able to use that distributor.....
Old Nov 7, 2008 | 11:52 AM
Damills's Avatar
Default Re: obd1 Vtec/nonvtec distributor question (EJ1 LS guy)
Can you use the ls dizzy if you cut one of the tabs off?
Old Nov 7, 2008 | 01:11 PM
EJ1 LS guy's Avatar
Not 100% sure....but I think you can re-pin it....
If thats what you mean....
I had my homie do it for me....and My car started
first try.....
Old Nov 7, 2008 | 03:12 PM
iwanttokillgod's Avatar
ej1 ls guy sorry your wrong
first try.....
you do not need to repin anything there both obd1 and yes the ls dizzy will fit the b16 or gsr if you cut off on of the mounting tabs
Old Nov 7, 2008 | 04:10 PM
Damills's Avatar
thx for the info
Old Nov 7, 2008 | 05:35 PM
EJ1 LS guy's Avatar
Default Re: obd1 Vtec/nonvtec distributor question (iwanttokillgod)
well ok..i guess...
but when I used my obd 1 gsr distributor
on my obd 1 ls it didn't start at all....
untill I got an ls distributor...
efjones9
Apr 16, 2010 11:35 PM
ek_civic96
May 6, 2008 12:58 AM
crxkidb16t
Oct 12, 2005 11:19 AM
thegreatwhitehope
Apr 20, 2004 05:26 AM
mattssi
Nov 12, 2003 09:19 AM
