springs switched?
Old Nov 7, 2008 | 07:30 AM
newtothescene's Avatar
Default springs switched?
i ordered a tociko kit to lower my car 1.5 inches. few days later, the fronts struts blew. is is possible the shop switched the springs or something? the front looks very low, but the back looks stock height. also, is it possible to use stock struts on the front and keep the tocikos on the rear without blowing the fronts or my car handling wierd?
Old Nov 7, 2008 | 10:31 AM
P_Adams's Avatar
Default Re: springs switched? (newtothescene)
There are differences between OEM struts and those modified for dropping purposes. The "drop" strut will collapse to a shorter length that the OEM to make up for the shortened suspension travel.
As to you query about mis-matched Springs / Struts; you'll have to take that up with who(m)ever you purchased them from. Hopefully it won't be a EBay store......
OEM struts will NOT work / last with a dropped suspension
P
Old Nov 7, 2008 | 02:02 PM
Default Re: springs switched? (P_Adams)
i got em from parts train. but i meant that is it possible to put the rear springs on the front and cause the struts to blow?
Old Nov 8, 2008 | 12:44 PM
FunnyVictor86's Avatar
i dont think its possible ... but the bigger strut/spring go in the rear ... smaller strut/spring go in front ...
Old Nov 8, 2008 | 06:09 PM
Default Re: (FunnyVictor86)
guess so....i'll just order some more tocikos and put em. thanks.
stepheneb
May 31, 2014 06:57 PM
oneprblmcat
Feb 3, 2012 05:01 AM
elmalouno
Nov 4, 2009 04:12 PM
E55TOSI
Honda Civic (2006 - 2015)
Oct 23, 2007 07:19 AM
M@
Oct 25, 2005 08:30 AM
