94 ex wierd passenger turn signal problem
Old Nov 7, 2008 | 04:01 AM
09metcalf.dylan's Avatar
Default 94 ex wierd passenger turn signal problem
it started the other night when my corner lens fell out and was wabling around held there by wires,when the headlights are on the right turn signal light stays on in the speedomeder and the rear turn signal, but they don't blink its just on steadywhen the lights are off the turn signal works fine on both sides
the left turn signal works fine when the lights are on
idk what it can be maybe a short any suggestions thanx>>>
Old Nov 7, 2008 | 10:15 PM
Duane_in_Japan's Avatar
Default Re: 94 ex wierd passenger turn signal problem (09metcalf.dylan)
Yes, a possible short or a bad ground that came loose due to the tension on the harness while it was bouncing around.
Old Nov 8, 2008 | 04:13 AM
jwicecold's Avatar
Check fuses under the hood and dash... But that is a strange problem... Your prolly gonna have to mess with a few things before ya figure it out.
Old Nov 10, 2008 | 02:41 PM
Default Re: (jwicecold)
i fixed it. it was the wiring lume up by the headlight the car was recently wrecked on that side. the wiring was pinched in between frame, so the wires were all crossing each other. and it did end up blowing some fuses...
thanks for all ur help.
jdm_ek_noob
12
Dec 22, 2014 09:09 PM
ridgeline08
May 29, 2011 10:38 AM
teggy182
Jul 28, 2008 05:38 PM
spoolinegsr
Oct 23, 2006 01:44 PM
SaTownTegGsr
Aug 20, 2004 11:45 PM
