Clutch and Flywheel Question!!! (RSX TYPE-S INSIDE!)
Old Nov 6, 2008 | 11:32 PM
mitcho's Avatar
Default Clutch and Flywheel Question!!! (RSX TYPE-S INSIDE!)
Alright im in the process of changing out my clutch and while im at it, im changing out to a lightweight flywheel. Should i go ahead and get a stage 1 or 2 clutch or will a OEM clutch(exedy brand) hold? anybody run with an oem clutch with a lightened flywheel? THANKS AGAIN!
Old Nov 7, 2008 | 09:53 AM
Type-Spaz's Avatar
DC5/EP3 MOD :)
well I guess all of this depends on your power goals. Stock clutch's will hold up to stock power. I just swapped my stock clutch out for the Competition Stage 4 puck clutch. But it feels like a stage 2 in drivability with the 10lbs flywheel.
If anything, I would go with at least a stage2 even if you aren't going for high horespower numbers just to have a stronger clutch since it's out.
Old Nov 7, 2008 | 11:04 AM
dc5RickK20's Avatar
Default Re: Clutch and Flywheel Question!!! (mitcho)
what mods do you have right now and what flywheel do you plan on going with?
Old Nov 7, 2008 | 05:09 PM
johnclaunch's Avatar
Default Re: (Type-'S'paz)
No puck clutch is going to have easy drivability especially with a lightweight flywheel. I have an ACT clutch (non-puck) and a 13lb flywheel and it is not that easy.
Just go with an OEM clutch with the OEM flywheel for the easiest driving.
Old Nov 8, 2008 | 09:27 AM
mitcho's Avatar
im lookin at a typeR flywheel. they're 10lbs and from honda so why not
Old Nov 8, 2008 | 01:43 PM
square_1's Avatar
Default Re: (mitcho)
I would go with a lightweight flywheel and a name brand moderate stage two clutch. If lucky you might even just get more life out of it compared to the Honda one? That would make it worth the extra right there. And even if you don't have high horsepower expectations it will take the abuse of driving hard better. I am looking at getting the Type R flywheel whenever I have to change my clutch. Hopefully with 64000 miles that won't be soon!
Old Nov 8, 2008 | 04:36 PM
aemciv's Avatar
Keep in mind that any light weight flywheel is going to decrease drivability, Dont know if you know how a lightweight flywheel will change your motor, but it will not hold rpms like a stock flywheel. So when you shift, the rpms are going to drop a lot faster. Also getting going is going to be a little harder as well with a low torque honda. Just letting you know. I would stick to stock flywheel with a DD. And keep in mind if you are going forced induction it is not good to have a lightweight flywheel with a high torque setup.
Old Nov 9, 2008 | 11:06 AM
Default Re: (aemciv)
I agree. I had to upgrade my flywheel to a Type S flywheel for my clutch. I got a lighter than stock Type S flywheel cheaper than I could get an OEM flywheel. It does drop RPMs slightly faster but not dramatically like an 8lb would. Getting the highest stage clutch kit and the lightest flywheel is not the optimal setup.
Old Nov 9, 2008 | 11:41 AM
hawaiiancb74's Avatar
i use a custom 9# and a action 6 puck, its easy to drive and reliable from anything bolt on to supercharged at 11#. i was just thru the break in period when my motor popped and light easy driving in downtown was cake..
in fact i have my set up for sale if your interested.
Old Nov 9, 2008 | 12:16 PM
Default Re: (hawaiiancb74)
9lb with 6 puck - easy? You must like that either on or off with no in between feeling.
Old Dec 4, 2012 | 03:43 PM
chase044's Avatar
Default Re: Clutch and Flywheel Question!!! (RSX TYPE-S INSIDE!)
Hahaha Im using the search function. Just thought I would add my .2 just to clear things up. There isn't much difference between a stage 2 pucked or solid disc. The difference would be in wether or not the disc is sprung or un-sprung. A un-sprung clutch is a pita. The spring in the disc are what make a clutch streetable or not. I wouldn't ever street a unsprung clutch Honda with over 200hp. Your would be screeching almost everytime you left a Stop.
HondaLuv3r4Life
Honda Civic (2006 - 2015)
Mar 2, 2015 05:02 PM
xkrntamax
Mar 27, 2010 04:55 PM
Flava
Sep 20, 2006 05:30 PM
allstockb18c
Jul 3, 2005 12:44 PM
beandip
Nov 23, 2003 11:31 AM
