96 Accord electircal problems......AGAIN 96 accord
Old Nov 6, 2008 | 05:56 PM
jimmy o.'s Avatar
Default 96 Accord electircal problems......AGAIN 96 accord
Well after i fixed the blinkers (again) on this accord that my buddy has and again has another elctical problem switch the driver power window will go down not up which im gessin is the switch cause it dosent pull power tryin to up but it does when you push it down my question is which wires can i junp to make the window go back up thanks
- its the drivers side front
Old Nov 6, 2008 | 06:08 PM
P_Adams's Avatar
Default Re: 96 Accord electircal problems......AGAIN 96 accord (jimmy o.)
Temporarily reverse the motor wires (two), select down - and the window should go up.
P
Old Nov 6, 2008 | 06:15 PM
jimmy o.'s Avatar
cool thanks worked like a charm
Modified by jimmy o. at 8:16 PM 11/6/2008
Old Nov 7, 2008 | 04:14 AM
P_Adams's Avatar
Default Re: (jimmy o.)
Glad you got it closed.
I've seen the master switch assemble on EBay from time to time, so you should be able to find one pretty cheap.
If not there, try Woodfins ( http://www.woodfins.com ), Cherry Auto ( https://www.cherry-auto.com ) or your local Auto Recycler as alternatives.
P
Ray Rocker
Mar 15, 2014 04:40 PM
b_hoov
Dec 12, 2008 07:15 PM
dang_erous
Nov 15, 2007 06:41 PM
Skitzo
Dec 4, 2004 01:00 PM
