1996 Accord v6 - EX water pump
Old Nov 6, 2008 | 03:31 AM
rbwdriven's Avatar
Default 1996 Accord v6 - EX water pump
So the wife went out in the car last night. She calls me telling me the car is overheating sitting in traffic.
I have a 96 honda accord v6 ex.
By the time she got home it was too late to work on it.
Since I have a v6.
I was looking at majestic honda to see about the water pump.
Is this the same as the 4 cyl where I have to do a timing belt change as well or is it like the picture shows that the water pump is on the back of the engine.
Thanks.
Old Nov 6, 2008 | 07:51 AM
Mr Yamada's Avatar
Default Re: 1996 Accord v6 - EX water pump (rbwdriven)
If you are changing the T-belt anyway, sure go ahead and do the water pump;[good time to change T-stat]
However, you should find out the reason for the overheating.
Such as be sure the cooling fans cycle and the T-stat is opening.
The one-eyed mechanic says "the car is low on coolant"
The two-eyed TECHNICIAN says "Why is the car low on coolant?"
Old Nov 6, 2008 | 09:48 AM
rbwdriven's Avatar
it is giving the same conditions as my rex which was the water pump.
So I'm gonna check it out tonight when i get home.
aschweizer2007
Sep 21, 2018 07:22 PM
forestcd6
Sep 9, 2010 08:22 AM
jhollister
Apr 3, 2007 03:45 AM
jamoore115
Oct 10, 2006 07:17 AM
1baddcivicsi
Apr 24, 2006 07:33 PM
