something's wrong w/ my teg
ok.. the other day i started to drive my integra and it was acting normal until i finally punched the gas pedal.. right when i did that in first gear it acted as if i was hitting a rev limit.. the tach bounced from like 4 to 3 then to 5 back down to 4.. it did this in all the gears.. it drives perfectly fine normal.. i can rev it all the way up to red line normally if i don't floor it.. my only guess is it needs a new fuel filter?
the car has about 149,xxx miles on it.. i have no clue what else it could be.. any suggestions?
thanks
thanks
then check for a
vacuum leak
Leaking EGR valve
Leaking head gasket
Timing belt or pulleys worn
Camshaft lobes worn
Fuel Pump not delivering enough fuel
Or air filter clogged.
If you have touched or messed w/any of these or didn't do the maintenace required on them then that might be the problem.
vacuum leak
Leaking EGR valve
Leaking head gasket
Camshaft lobes worn
have you checked your spark plugs? whens the last time you changed em? usually.. the best things to check out for bogginess like that are:
-spark plugs
-spark plug wires
-fuel filter
-air filter
-vacuum lines
-spark plugs
-spark plug wires
-fuel filter
-air filter
-vacuum lines
Silver89crx
Dec 30, 2007 04:24 PM
thehondaguru
Nov 21, 2002 12:02 PM
