another clutch issue
Old Nov 5, 2008 | 06:44 AM
mr. robot-o's Avatar
Default another clutch issue
So i did a search and didn't find anything quite similar to my situation. It rained last night and this morning when i went to start my car i noticed i could push my clutch all the way in and it was like there was no resistance until you reached the disengaging point which had moved towards the front of the car. It was like this for a while but as i got closer to work, the clutch seemed to return to normal... wtf is going on?
Old Nov 5, 2008 | 06:57 AM
Tim2179's Avatar
eight equals equals equals D
Community Builder
Loved
Default Re: another clutch issue (mr. robot-o)
Did you check the fluid level in the reservoir?
Old Nov 5, 2008 | 07:04 AM
Default Re: another clutch issue (Tim2179)
no i haven't had time yet but i will, thanx
Old Nov 5, 2008 | 07:25 AM
weavertime1's Avatar
Check for a leaking clutch master cylinder on the inside of the car. Look up under where your clutch pedal is with a flashlight, and I think you will see what I am talking about. If not there could also be slave cylinder issues (on the trans.), a leaky clutch line, etc. This is a good place to start however there are many other issues that could be affecting your clutch. Good luck!
Modified by weavertime1 at 10:41 AM 11/5/2008
Old Nov 5, 2008 | 07:29 AM
Default Re: another clutch issue (weavertime1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by weavertime1 &raquo;</TD></TR><TR><TD CLASS="quote">Check for a leaking clutch master cylinder on the inside of the car. Look up under where you clutch is with a flashlight, and I think you will see what I am talking about. If not there could also be slave cylinder issues (on the trans.), a leaky clutch line, etc. This is a good place to start however. Good luck! </TD></TR></TABLE>
Thank you for the help, i really don't know too much about clutches and stuff so i really appreciate the help
Old Nov 5, 2008 | 09:29 AM
twentyhurtz's Avatar
agreed above, i had that issue where its like you only have half a clutch pedal, my problem was low fluid level, and found out that it was the master clutch cylinder, i could see it leaking down the inside of the firewall, if the leak is not bad you can keep adding fluid until you get a chance to change the cylinder out, if it gets too low its gonna get close to impossible to change gears
- i got out in the middle of no where, no fluid and my resevoir was very low, i had to borrow just a little fluid from brake resevior to put into clutch to make it back to safety,
Old Nov 5, 2008 | 12:02 PM
GSRalive's Avatar
You should bleed your clutch line, it is possible that you got air in your hydraulic line. I had the same problem and that is what i did, and it has been fine every sense. You said that it was raining out, so that means the temperature has dropped, this could cause one of your seals to leak a little causing air to enter the hydraulic line.
Old Nov 5, 2008 | 12:19 PM
Default Re: another clutch issue (GSRalive)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSRalive &raquo;</TD></TR><TR><TD CLASS="quote">You should bleed your clutch line, it is possible that you got air in your hydraulic line. I had the same problem and that is what i did, and it has been fine every sense. You said that it was raining out, so that means the temperature has dropped, this could cause one of your seals to leak a little causing air to enter the hydraulic line.</TD></TR></TABLE>
True, but the only way to get air into the hydraulic line is a leak somewhere...
Old Nov 9, 2008 | 06:27 AM
killacam661's Avatar
bleed your clutch and make sure your clutch cap gasket were you add fluid is sealing right and is not damaged
blacklabel14
Feb 3, 2011 12:32 PM
blacklabel14
Feb 2, 2011 08:48 PM
otakueric
Oct 6, 2004 09:44 PM
range
Dec 1, 2003 02:01 AM
geminis2k
Nov 20, 2003 11:33 AM
