ACT, exedy, Competition Clutch, Clutch Master on sale now
FX300 System utilizes the Power Plus I Hi-Leverage Pressure Plate with the Steel Back Segmented Disc to provide best performance for your vehicle, especially under heavy-duty street conditions and weekend racing with a normally aspirated car equipped with cylinder head work and/or hotter cam(s), or with medium-boost turbo or super-charger, or up to 100HP NO2. Here are few tasks you should expect your FX100 to master - only slightly increasing the pedal pressure, offering longer life than stock, increasing the torque capacity, and affording normal clutch feel during engagement and disengagement; thus, giving you a smoother operation.
FX400 System utilizes the Power Plus I Hi-Leverage Pressure Plate with a Ceramic Disc to provide best performance for your vehicle, especially under extreme duty street or road/drag racing conditions. Built using special 4-wing Ceramic Button design disc, FX400 provides long life, great holding capacity, tremendous heat dissipation and increased torque capacity.
FX500 System utilizes the Power Plus II Hi-Leverage Pressure Plate with the Four-puck Disc to provide best performance for your vehicle. This is an extreme system designed especially for maximum holding capacity with no compromises. The FX500 utilizes a Sintered Iron friction material, which allows it to hold all the power and dissipate the unwanted heat in no time; thereby, increasing the torque capacity.
Clutch Master
ACT Clutch Kits and ACT Pressure Plates are ideal for increasing engine horsepower and torque. The ACT high performance clutch kits combines the strength of pressure plates to transfer the power to the dive-train. You are also offered the freedom to customize the kit for all kinds of applications, considering the type of driving situations. For instance, for street use, a long-lasting clutch, like the ACT stock, modified or performance street disc that offers a responsive feel, smooth engagement and quiet operations, is ideal. Mated with an ACT heavy duty pressure plate will provide a comfortable, smooth driving experience.
And if you are looking for a race application that requires quick shifting and hard solid engagement, ACT clutch kits should include either a 4-pad or 6-pad solid/spring hub race disc, with an ACT Xtreme pressure plate.
You can also opt for different ACT clutch kit combinations. For this, you'd need to determine the amount of power your engine will be making or estimated to make.
ACT Clutch kit
ACT Clutch kit
Sprockets
Nov 3, 2011 08:04 AM
"CHESTER"
Dec 5, 2003 12:04 PM
