gsr front suspension fork
Old Nov 4, 2008 | 10:22 PM
danielblushtein's Avatar
Default gsr front suspension fork
Hey i bought a 95 civic hatch with a 95 gsr engine. I am not sure if the guy changed out the front suspention to gsr because i bought a set of tokico shocks that were on a delsol and the front shocks were too small for the fork.
Are the front civic fork holes a bit smaller then gsr or same? please help Thanks for reading this
Old Nov 4, 2008 | 11:07 PM
BlueIntegraBoy's Avatar
Default Re: gsr front suspension fork (danielblushtein)
No, the forks are the same
Old Nov 5, 2008 | 12:26 AM
Default Re: gsr front suspension fork (w3aselll)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by w3aselll &raquo;</TD></TR><TR><TD CLASS="quote">BUMPP</TD></TR></TABLE>
Hey dumbass, stop bumping threads.
Old Nov 5, 2008 | 01:34 AM
dumafit's Avatar
if the shocks are too small in diameter for the shock forks, you probably have some 88-91 civic or crx shocks
Old Nov 5, 2008 | 07:28 AM
weavertime1's Avatar
Default Re: gsr front suspension fork (dumafit)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dumafit &raquo;</TD></TR><TR><TD CLASS="quote">if the shocks are too small in diameter for the shock forks, you probably have some 88-91 civic or crx shocks</TD></TR></TABLE>
That is the most likely answer...and yes 92 - 95 civic and 94 - 01 integra forks are the same! Good luck!
Old Nov 5, 2008 | 09:43 AM
Default Re: gsr front suspension fork (weavertime1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by weavertime1 &raquo;</TD></TR><TR><TD CLASS="quote">
That is the most likely answer...and yes 92 - 95 civic and 94 - 01 integra forks are the same! Good luck! </TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dumafit &raquo;</TD></TR><TR><TD CLASS="quote">if the shocks are too small in diameter for the shock forks, you probably have some 88-91 civic or crx shocks</TD></TR></TABLE>
oh so the older civic/crx have a bigger fork???
Old Nov 5, 2008 | 09:56 AM
The old civic/crx have a smaller diameter opening in the front shock forks. Therefore the shock diameter is also smaller, so at some point in time someone may have switched the whole unit. Just my guess!
lil_kev
Suspension & Brakes
Dec 30, 2007 09:27 AM
Hoosier Daddy
32
Aug 29, 2007 04:51 PM
AmbiguousCivic
Sep 5, 2006 12:56 PM
Leets
Apr 15, 2006 02:27 PM
Soda Popinski
15
Jun 30, 2004 10:04 AM
