Suspension & Brakes Theory, alignment, spring rates....
spoon brake setup on crx
Old Nov 4, 2008 | 08:07 PM
SaGaEF8's Avatar
Default spoon brake setup on crx
can anyone help me out on wat parts from wat year car i would need to use to do a spoon setup on my crx? any help would be greatly appreciated
Old Nov 5, 2008 | 08:51 PM
jxh_28's Avatar
i wish i knew, man!
Old Nov 7, 2008 | 01:30 PM
Patty's Avatar
Default Re: spoon brake setup on crx (SaGaEF8)
I'm thinking about the same set up but can't get any clear info. But this is what I do know. Fastbrakes has 11" brake upgrade for CRX's that uses Integra Type R calipers so I planning on buying that minus calipers and using the Spoon twin blocks. For DIY basically you need 99-00 Civic EX knuckles, an 11in. rotor drilled to 4x100, a 3mm spacer, and of course wheels that will clear it. If you contact fastbrakes I'm sure they'll be able to set you straight. That's my plan but I'm waiting until I have the money.
SaGaEF8
Nov 4, 2008 07:59 PM
Acurapwrd
11
Mar 28, 2006 09:13 PM
Acurapwrd
Mar 26, 2005 09:56 PM
