95 integra turn signals dont work
can ne one help my turnsignals on my 96 gsr is not workin I checked the fuse underdash and the one in the hood their still good. also check the relay under the dash and its fine also. its not the clicker( the black piece with headlight switch) cuz i took off and plugged it into my other teg and it works fine? NE other solution or ideas on whats wrong ? the hazard light works they light up but they dont click( signal) back one also light up but doesnt blink either
HELLLLPPPPP MEEEEE!!!!!
there was an alarm on it could it have caused a problem?
don't think it could've been an alarm problem.
Do you have euro side marker lights that may be affecting the electrical circuit (bad splice etc.) ??
-Rage
-Rage
The turn signal bulbs are dual-filament. Basicly there are two circuits within the turn signal bulbs. (One for ON, one for BLINK)
Inspect the filaments in your bulbs, thay can die and still look OK.
Just go to the auto-parts store, and get a replacement dual filament bulb.
BrayzieEF9
Feb 7, 2010 11:17 AM
zc89hatch
Feb 6, 2008 12:50 PM
