tires
Old Nov 4, 2008 | 05:39 PM
subhu1030's Avatar
Default tires
hey guys...i need to replace my tires, and i wanted to go with 225/40/18 .....any reccomendations where and which brand should i go with?
Old Nov 5, 2008 | 07:15 AM
Duane_in_Japan's Avatar
Default Re: tires (subhu1030)
Mainly goes with your pocket book then go to E Bay, should be lots of good deals there, stick with name brands though. After someone tells you they will fit or not, I do not know, sorry. Do you know what offset you need too?
Do you already have 18" rims I should ask. You just want to increase the size of rubber to the ground?
Old Nov 5, 2008 | 07:37 AM
nsxtasy's Avatar
H-T Order of Merit
Stickied at the top of this forum is a topic called
Forum Rules and FAQ - READ BEFORE POSTING
It says:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Forum Rules and FAQ - READ BEFORE POSTING &raquo;</TD></TR><TR><TD CLASS="quote"><FONT SIZE="4">Tires FAQ</FONT>
Which tires should I get?
This depends on what you're looking to get out of the tire. If you're still not sure what to get after reading the above information, make a new topic and tell us what you intend to use it for. <FONT SIZE="4">In that topic, make sure to answer the following questions:
- What kind of car you have (year, model, version)
- What size wheels you have
- How the tires will be used (daily driving, autocross/track/dragstrip)
- What kind of weather the tires will be used in (dry, rain, snow)
- What your preferences is in the trade-off between value (low purchase price and/or long treadlife) vs performance
</FONT></TD></TR></TABLE>
Old Nov 8, 2008 | 08:22 PM
subhu1030's Avatar
Default Re: tires (nsxtasy)
I have a 99 honda accord 4cyl; 18in wheels with 215/35 right now; daily driving is the main deal with the tires; usually in dry weather; i would like low road-noise, cheap as possible and prefer z-rated tire.
Sorry for not answering the questions previously.
Old Nov 9, 2008 | 07:41 AM
nsxtasy's Avatar
H-T Order of Merit
First, you didn't mention whether your Accord is a DX, LX, or EX. If it's a DX, I would definitely stick to size 215/40-18, which is a lot closer to your stock size (195/70-14) than the 225/40. If it's an LX or an EX, the Tire Rack recommends 215/40-18, but 225/40-18 is actually closer to (slightly larger than) the outer diameter of your stock size (195/65-15); I don't know whether they recommend 215/40-18 because 225/40-18 may rub, or if they're just playing it safe.
In 215/40-18, I recommend the Sumitomo HTR Z III ($111/tire at the Tire Rack) or the Kumho SPT ($117/tire). Both offer very good dry and wet traction, last a reasonably long time, and are inexpensive.
In 225/40-18, I recommend the same two tires - the Sumitomo HTR Z III (also $111/tire) or the Kumho SPT ($90/tire).
Don't confuse these tires with other tires that have similar names. Sumitomo's other tires (like the HTR Z and HTR Z II) are nowhere near as good as the HTR Z III.
stdefhatch
Jun 15, 2008 08:14 PM
IHaveYourThonG
Mar 31, 2008 01:09 PM
whiteej1
Aug 7, 2007 09:44 AM
UCLA.lion
Apr 12, 2006 07:05 AM
FastAllmotorLsVtec
Apr 9, 2004 04:57 PM
