Fuel pump ????
Old Nov 4, 2008 | 03:13 PM
connor53's Avatar
Default Fuel pump ????
Ok i have a 99 civic ex and swapped a jdm b18c gsr/sirg engine into it. My question is- I am still using the ex fuel pump, is there a differance between the ex a gsr pumps? As in since im using the ex am i losing power. if that sounds right
Old Nov 4, 2008 | 04:00 PM
hatchling37's Avatar
Default Re: Fuel pump ???? (connor53)
Integra fuel pump 17040-ST7-A33
Civic fuel pump 17040-S02-L01
Not same part. Couldn't tell you if the Integra pump moves anymore gas than the Civic, but I would imagine it would sustain proper fuel pressure at the rail, worst case, get an FPR?
Old Nov 5, 2008 | 12:18 PM
connor53's Avatar
Default Re: Fuel pump ???? (hatchling37)
yeah i new the two pumps are different. i just wanted to know if the gsr pumps more than the civic.
Old Nov 11, 2008 | 10:12 AM
vtec_4800's Avatar
the gsr pumps more fuel in but look at it this way u will be svin gas mileage
Old Nov 13, 2008 | 10:34 AM
ddd4114's Avatar
Default Re: Fuel pump ???? (vtec_4800)
Why would a higher capacity pump waste more fuel if the pressure and injector duty cycle are held constant?
Old Nov 13, 2008 | 05:16 PM
mr.sky's Avatar
it wouldnt use any more gas...
Old Nov 13, 2008 | 06:16 PM
patriot's Avatar
Default Re: (mr.sky)
If you keep voltage the same then the pressure increase would come from the added volume by the new pump...which is why you should run a FPR to DECREASE fuel pressure when using a higher flow fuel pump.
Udcivic
Mar 11, 2009 12:19 PM
civroc95
Mar 29, 2006 08:20 PM
bulori
Sep 25, 2004 11:41 PM
SLOAZZ95
Aug 21, 2003 10:56 AM
ArchAngel Sabastian
Aug 18, 2003 11:52 AM
