Suspension & Brakes Theory, alignment, spring rates....
CAMBER / TOE / CASTER
Old Nov 4, 2008 | 02:04 PM
ek guy's Avatar
Default CAMBER / TOE / CASTER
here are the specs for my last Alignment. im thinking they did'nt do a very good job aligning everything up. What do you guys think?
left front
camber .04
caster 1.4
toe .04"
right front
camber -.02
caster .04
toe .04"
left rear
camber -1.3
toe .06"
right rear
camber -1.8
toe .06"
Modified by ek guy at 6:32 AM 11/5/2008
Old Nov 4, 2008 | 03:09 PM
Tyson's Avatar
Default Re: CAMBER / TOE / CASTER (ek guy)
shrug. kinda toed in a bit much but not horrible. whats the middle spec for rear toe on an EK?
you have a bit of positive camber. but im assuming youre not lowered at all.
otherwise looks fine. cant do much about the cross caster.
how does it drive?
Old Nov 4, 2008 | 04:05 PM
hatchling37's Avatar
Looks good to me, I usually add in a little positive toe, so it'll kind of settle back to zero when you are driving. What are your SAI and included angles? What year and model car is this on?
Old Nov 4, 2008 | 04:29 PM
alphalanos's Avatar
Some front neg. camber would be nice if you like cornering at all.
Old Nov 5, 2008 | 05:31 AM
ek guy's Avatar
Its a 1997 civic dx hatch back. the car is lowered about 2 inches all the way around. I have a camber kit on the front. they adjusted everything for me.
how much camber should i be running?
the car feels loose. it has Koni blues with sprint springs.
Modified by ek guy at 6:38 AM 11/5/2008
Old Nov 5, 2008 | 01:07 PM
Default Re: (ek guy)
They adjusted the kit to near factory spec. A little negative camber is a good thing. I would say between -1 to -1.5 degrees is plenty, just make sure the toe is set well; bad toe along with negative camber will melt tires.
Old Nov 5, 2008 | 05:10 PM
Tyson's Avatar
put some neg camber up front.
you need another alignment if you change the camber tho.
whats the rear toe supposed to be?
Old Nov 5, 2008 | 07:11 PM
ek guy's Avatar
Default Re: CAMBER / TOE / CASTER (Tyson)
im going to run -1.0 up front and see if that helps.
im going to go ahead and change my inner and outer tie rod ends and see if that improves anything. should i shim the rear to fix the camber or is the negative camber okay with my toe being .06"?
as for the rear toe... im not sure right off what the factory spec should be.
bopbop93030
Suspension & Brakes
Apr 8, 2008 04:08 PM
austrian type-R
Jul 23, 2003 07:42 AM
WheAs MaI MojO
Oct 11, 2002 08:06 PM
yoshi234
Dec 27, 2001 01:11 PM
keys
Sep 7, 2001 11:21 AM
