need help on frankenstien build
i need help my car is running really really rich dont know how to correct the problem when v-tech hits the car falls on its face need help anyone know how to run the vacuum line for the map sensor motor is a b20 with a gsr head its going into a 93 acura integra da
sorry for the type o. i had my little bro post this while i was at work. it was supposed to be v tec lol i had it tuned and they r saying my ecu is bad how would it be bad they tuned it and now it is fine till i am at full throttle
If the ecu were bad the car most likely wouldn't even run. Are you getting a CEL? What is vtec crossover set to? What IM do you have? Need more specs on the build.
v tec crosses over at 5200 and my cel code is a electrical load detector code it is code 20 wat eles u need on the specs i said it it is a b20 bottom and a gsr head going in a da integra
EF_b- Series
Jul 5, 2007 12:22 AM
