need help h22 swap on my 93 prelude
need help ive been doing b-series swap on eg-ek but i have a prelude that i wanna put a h22 swap what are the stuff that i need to do the swap can i use the old engine mounts?and also i need to add some vtec wire to ecu pls. need some info thanks
https://honda-tech.com/zerothread/2168311 All the info you need for h22 swap can be found there.
Not sure about reusing the mounts, but i think you can, someone else needs to confirm.
As for the harness, yes you can use it, but it's not wired for vtec so you're gonna have to pin wires to the ecu harness along with using the right sensors that go to the h22.... IAB solenoid, vtec solenoid, vtec pressure switch, and knock sensor. Not too hard to do as long as you follow the pin diagram, it should be in the FAQ's. You also have to find a 12v source for the IAB, i ran it directly to the battery.
Depending on whether you go with an internal or external coil you may have to extend the thermostat sensor and egr sensor.
i used the h22 and its plug in to the f22 harness but how what about the vtec harness is it gonna work or i still have to connect a line to the ecu?im using a h22 jdm ecu
EuRoBrO
Jul 20, 2004 09:54 AM
